Page 3 of 56 FirstFirst 1234567891011121353 ... LastLast
Results 21 to 30 of 558
Thread: HVAC Control on Car PC through Serial Port.
  1. #21
    FLAC Mastero's Avatar
    Aug 2001
    India
    Quote Originally Posted by shauns
    hmmm im asuming you would have to have a digital A/C unit?
    i have an 05 altima, that has knobs.
    No its meant for the Knobs ... to make it digital and computer controlled..
    Mastero
  2. #22
    Aug 2001
    India
    Here is the software .. very basic .. but usefull and has all required controls
    Let me know ...
    Mastero
  3. #23
    FLAC mauri's Avatar
    Jan 2004
    Yes, you basic sw work correctly in XP and RR embedded.
    Do you make to know the developments hardware and sw, and interesting the project....
    You have an electric scheme to see?
    Mauri
  4. #24
    Aug 2001
    India
    The hardware shall be ready tommorow... will post pics
    Mastero
  5. #25
    FLAC mauri's Avatar
    Jan 2004
    OK!
    Mauri
  6. #26
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Great, I cant wait. subscribed to thread
  7. #27
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Very nice!!
    Looking forward to see the hardware.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  8. #28
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    will it work for a 1994 ford explorer :-P?
  9. #29
    Jan 2004
    California
    Yea tell us more about the kind of controls you have to have to make this work. What was this designed for (what car do you have)
  10. #30
    Aug 2001
    India
    Ok this is a very simple but very useful hardware ..
    Every car a/c has a blower and a compressor. The blower always has three wires for speed 1 ~2 ~3 when you touch these wire to +12v the blower goes on the desired speed. The knobs for the blower speed does this.
    Then is the compressor that again is only one wire when touched to +12 the compressor clucth is activated making a cling noise.
    Now what my hardware does is uses the three wire from the blower and one wire from the compressor.
    You connect the three fan speed and the compressor wire to the hardware. when you start the unit (A/C on in the software) the blower is on at the same speed it was the last time it was on. The compressor will start after a delay of 30sec so there is no immediate load on the system (Blinking LED showing compressor on standy)
    Then the compressor will kick on. There is a two digit numeric dispaly showing the current temp when you press the fan switch it changes the fan speed to 1~2~3~FA (fan auto) when in fan auto the fan speed is controled with the temp say if its to hot the fan will be on full and as the temp drops the fan will go solwer 3~2~1 ..
    The temp is set from 16 ~30 deg C to set the temp you press the temp button on the software the display will show the set temp with the Blue and red arrow buttons you can either set the cutoff temp higher or lower.
    The temp is sensed with the help of a sensor. A tiny black thing with wire this sensor is to be placed inside the blower so the actual temp is recorded.
    OK now the best part ... this unit also has a REMOTE CONTROL..(for emergency) say if one day your PC craches on a hot sunny afternoon ..... Happend to me that means you cant use the A/c and you know how the turkey feels.
    Well that when you can use the remote control and start the a/c set the temp fan speed ... NEVER use the PC and the RC together to control the unit. Will give undesired results. Always off the unit from the remote if used before starting the PC.
    And last the Unit has a built in delay on timer that means it will start 10 sec after the pc boots thus eliminating the strange behavior of the LPT port.
    The small A/C software which is included in the software package just makes sure the port bits are set to 0.
    Well thats it for the brief documentation
    How much should the delay time be .. i have calculated 10 sec more than enough.. open for suggestion.
    Cheers
    Mastero
  1. Using PC to control lighting.
    By gguy in forum General Hardware Discussion
    Last Post: 10-16-2007, 08:11 PM
  2. Kenwood In-dash Monitors to control pc?
    By DrBuzzo in forum LCD/Display
    Last Post: 12-08-2004, 08:21 AM
  3. cd changer control to control the pc
    By babas151 in forum General Hardware Discussion
    Last Post: 10-26-2004, 12:21 AM
  4. software to control pc from ipaq
    By spud42 in forum Software & Software Development
    Last Post: 11-13-2001, 01:56 AM
  5. Using a pda to control a normal PC
    By All4Norway in forum General Hardware Discussion
    Last Post: 08-27-2000, 08:52 AM
