Page 43 of 56 FirstFirst ... 333435363738394041424344454647484950515253 ... LastLast
Results 421 to 430 of 558
Thread: HVAC Control on Car PC through Serial Port.
  1. #421
    FLAC Mastero's Avatar
    Aug 2001
    India
    From the above pics //
    Your system is vaccum even for ac and circu... but there is a switch which electronically controls the air flow more like a solonide switch or relay type.(The big thing with yellow tape) so when power is applied it opens or closes the vacum supply. If its this way then your good to go.
    Check and let me know
    Mastero
  2. #422
    Jun 2005
    MD, USA
    yeah, im pretty sure i can get it to work in one way or another. im not ready to purchase yet, was just curious.
    me in school = poor bum
    maybe sometime in a couple of months i will be ready to purchase. i dont suppose that if i only wanted one temperature sensor and no external led display you could knock a couple dollars off huh?
    i know it would probably be extra hassle thats not worht the small savings but let me know.
    if the program is written in vb you can just throw the centigrade temp value into an equation to spit out farenheit. im sure you can in other things, its just that i know how to do it in vb, so i know it could be done.
  3. #423
    Oct 2006
    Maestro you live up to your name. Looks awsome...
    Is the user manual old or new? I live in a colder area, wondering if there is a compressor cut of with v2 of your design?
    Thanks.
    PS Anyone done an install on a Nissan s15 200sx or the similar?
    Cheers.
    Nick.
  4. #424
    Aug 2001
    India
    Quote Originally Posted by eliptoid View Post
    Thanks.
    Cheers.
    Nick.
    Thankyou,
    The Ver 2 is completely new with new manual etc...
    Yes compressor Cutoff can be set at a specific temp say 20 then when temp reaches 19 it cuts off the compressor and when the temp reaches 20 it starts again. Can also be switched on and off manually.
    Cheers
    Mastero
  5. #425
    Constant Bitrate S2K12's Avatar
    May 2006
    Perth, Western Australia.
    dunno much about a/c but is that the same way climate ctrl works? ive been thinking of getting jdm s15 1din climate control for my skyline but if this can do everything that unit can do (perhaps more?) then ill just get this.
  6. #426
    Aug 2001
    India
    This unit is based on the same concept with the requirement for PC connectivity via serial port.
    So one can have climate control on the finger tips
    "BUT"
    One should be able to wire it up. and be familiar with the A/C system of the Vehicle working with.
    Belive me its not that hard.... just need common sense.
    Cheers
    Mastero
  7. #427
    Variable Bitrate markland556's Avatar
    Jun 2005
    Bellevue, WA
    is there like an upgrade kit?? Because i have the old board and its useless to me with only the servos...
    96' Mercedes Benz C36 -Matte Black-
    Status..::... {##------}25%~~ back to planning
  8. #428
    Aug 2001
    India
    No sorry there are no upgrade kit as the two boards are 90% different. BUt u can make the Add on for electronic connection ... go back a few posts its there.
    Cheers
    Mastero
  9. #429
    Oct 2006
    I have read the thread and have not seen anything on this yet. Will the system work with Dual Climate Control? Also I like the display that is on my hvac unit. Is there any way to get the temp and vent settings to display on the monitor. If this is not possible could it be adapted to use the digital display from my hvac instead of the 2 digit display. I am very new to this scene so please bear with me on this. pic of current hvac. car is a 99' Corvette
  10. #430
    Oct 2004
    NY
    what your talking about is very possible, but would never fit in within the scope of this project, which is designed to be as universal, & there for widely usable by many.... yours would require quite a bit of custom work to pull off, & then it wouldn't be good for anyone else but you or the real slim chance someone else with a similar setup might... a one off setup built especially for you with no real universal appeal would cost you way more than these kits.... but possible
  1. Using PC to control lighting.
    By gguy in forum General Hardware Discussion
    Last Post: 10-16-2007, 08:11 PM
  2. Kenwood In-dash Monitors to control pc?
    By DrBuzzo in forum LCD/Display
    Last Post: 12-08-2004, 08:21 AM
  3. cd changer control to control the pc
    By babas151 in forum General Hardware Discussion
    Last Post: 10-26-2004, 12:21 AM
  4. software to control pc from ipaq
    By spud42 in forum Software & Software Development
    Last Post: 11-13-2001, 01:56 AM
  5. Using a pda to control a normal PC
    By All4Norway in forum General Hardware Discussion
    Last Post: 08-27-2000, 08:52 AM
