Page 47 of 56 FirstFirst ... 3738394041424344454647484950515253545556 LastLast
Results 461 to 470 of 558
Thread: HVAC Control on Car PC through Serial Port.
  1. #461
    FLAC Mastero's Avatar
    Aug 2001
    India
    Quote Originally Posted by barnyard View Post
    Climate_Control_Fan_Speed_4.jpg is missing...
    FIXED
    mastero
  2. #462
    Aug 2001
    India
    H3rk Wow so many questions in one go
    Three digit change can not be done with the software is hard programmed in the software of IC-C
    All outputs are ground.
    I dont understand what you want to do.?
    These are gonna be made in batches of 20nos first batch is up for sale.
    No the preset can not be altered as its hard coded in the Microchip. The software is just there to send commands to the unit not change any settings of the unit.
    Current drawn shall be posted here and updated in the manual.
    There are no mounting holes. Find a space and drill your own as per your needs. Thats why i kept this as a single side PCB.
    All connectors are included with housing and pins. You will have to just make your own cables.
    Phew .. any more questions
    Cheers
    Mastero
  3. #463
    Variable Bitrate bns2000's Avatar
    Nov 2004
    Russellville, AR
    Aircon-2 coms in a DIY KIT form only. What happened to the already made ones? I mean I can solder a little but my skills are very limited.
    CENTRAFUSE™ From Flux Media
    The Ultimate Infotainment Interface
    Download V1.20 from there site now!!!!
    Download the new 2.0 RC1 From here Linky
  4. #464
    Sep 2006
    Ok one more stupid question, i just read the manual and it seems you either have to use all servos or all switchs if u dont modify the software. Is that how its setup?
  5. #465
    Aug 2001
    India
    If you want readymade that can be done for a charge.
    In the settings page u can chose which servo to use by selecting the desired servo.
    Meaning you can have servos for vent but output for heat and circulation. It can be done.
    Mastero
  6. #466
    Oct 2006
    Las Vegas
    so this couldn't be done? or something more correct, but along the same lines?:
    Dim TC 'Temperature that comes from card'
    Dim TF 'Temperature in F'
    TF is (TC*9/5)+32
    Check Box in Settings
    Yes= display TF for all temps
    No= display TC for all temps
    or maybe Dim TU 'or something similar' use it for all displayed temps and:
    Yes then TU = TF
    No then TU = TC
    temperatures sent from the software to the card would have to be in C I assume (ie for the compressor settings)
    so those temps would have to be converted back and rounded before sent to the card.
    ???????????? Pretty please, tell me this is possible. (no lies)
    As for the question that you didnt understand:
    I have, as I have stated before, one servo in my system. It is a servo amplifier that utilizes any voltage from 0-12V and provides a corresponding position (Analog). There are in theory infinite positions between the 0V and the 12V set positions. I would prefer to control this servo with an analog 0-12 volt signal. I know there is hardware made by a company in canada I think, their products are called Phidgets. The phidgets are I/O devices that can be controlled by software (VB6 and similar are listed on the site) via usb. One of the products they produce, provides analog output.
    I want to know if its possible to modify the software you provide to send the control temperature to a seperate device like this phidget. I want to know if I can set up a new control associated with this output that provides more temp settings (lets say 10)to control the temp door more precisely, and I want to know if a slider control can be set up in addition to up/down arrows to control this temperature.
    So in short, is it possible for this VB6 program to be modified to read/write to/from other usb hardware?
    Thanks for your quick and thorough reply to my previous questions
  7. #467
    Aug 2001
    India
    h3rk ...
    Lets get one thing clear the software is there just to send command to the Unit. It can not modify a Microchip's preprogramed software. ITS IMPOSSIBLE!
    If you want a three digit display, changes has to be done from inside the Microchip software and even the hardware changes.
    If you want F then i suggest using LM34 with the current setup it will display the temp in F but 99 is the max deg it can display.
    As for the phidgets thing it is not possible with the current setup.
    You can modify the current setup to control a servo from 500 to 2340 steps 180 deg movment. for tis u will have to modify the software.
    Cheers
    Mastero
  8. #468
    Oct 2006
    Las Vegas
    Quote Originally Posted by Mastero View Post
    From what I can see '500 to 2340' are possible servo positions, what I need are greater than 5 preset positions within that scale.
    What is the maximum number of positions that I can send to the servo driver (with software modification). I see in the manual that there are 5 positions under 'Set Temp Locations' in the Climate Control Settings. Is it possible to have more or is that a limitation?
    Is the software open source? I think I remember reading previously that it was/would be.
    Seems to me that the software also provides some user interface functionality. It communicates temperatures to the user, in addition to controls.
    All I was wondering was if those displayed temps on the UI can be manipulated only for display purposes on the screen my theoretical software mod would leave the temps communicated to the hardware in C.
  9. #469
    Oct 2006
    Las Vegas
    Oh hell, I'll just buy it and see. Maestro, your website will be hearing from my credit card shortly.
  10. #470
    Aug 2001
    India
    Well any other questions ?
    Ita avalible in assembled form also!
    Mastero
  1. Using PC to control lighting.
    By gguy in forum General Hardware Discussion
    Last Post: 10-16-2007, 07:11 PM
  2. Kenwood In-dash Monitors to control pc?
    By DrBuzzo in forum LCD/Display
    Last Post: 12-08-2004, 07:21 AM
  3. cd changer control to control the pc
    By babas151 in forum General Hardware Discussion
    Last Post: 10-25-2004, 11:21 PM
  4. software to control pc from ipaq
    By spud42 in forum Software & Software Development
    Last Post: 11-13-2001, 12:56 AM
  5. Using a pda to control a normal PC
    By All4Norway in forum General Hardware Discussion
    Last Post: 08-27-2000, 07:52 AM
