a servo would be so much easier to use than a linear actuator
With that type of system, you may be able to integrate a linear actuator into the system, to pull and push the cable. Not sure how much force you will need, or the amnount of travel, but I am thinking that the travel shouldn't be all that much because it is the know moving the cable. I bet the max movement is a couple of inches. An actuator should easily be able to handle that. As far as strength, that might be a matter of trial and error. I will warn you though, most actuators you will find will be gib bucks, say in the 200 dollar range although you may be able to get one cheaper.Originally Posted by J's89
Integrating it with the Mastero device shouldn't be too hard. Would just need to add a relay or two. Maybe Mastero can chime in on that.
Michael
Any pics for this?
www.mobile-effects.com
Free file hosting, picture gallery hosting for installs, PM me.
Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
There is one vacuum line from the engine bay that supplies vacuum to either a four or five way connection on the back of the control cluster. Rotating the switch supplies vacuum to the desired combination of vents, defroster, floor, etc. The other end of the vacuum line connects to a diaphram "actuator", or motor whichever is the correct term. It in turn raises or lowers rotating lever that extends out of the sealed evaporator core box which is attached to the door that directs the internal air flow of the system. Did any of that makes sense? I'd really like to do this. However, a $200 actuator to get the job done is out of the question!Originally Posted by Mastero
Mainly because I have to first buy another AC system to install... I deleted it so I could go fast. It was a brilliant decision...I should have slept in that day.![]()
I know with my truck, it wasnt as simple as that.
I am really interested in this project, and I know you do great things, but what about heat? Where I live, we have hot summers and cold winters, so I need heat and air conditioning. It sounds to me like you can't control the temperature beyond making it cooler with the AC
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
Total spent on wedding so far: $3885.79
Thanks to everyone for your support.
I'M DEBT FREE!!
yea, i know what your talking about...I'm a Ford man...One way to do would be to get a couple of solionds that could control the vacuum just as the switch did but give you a way to control it...wouldn't be that hard...you would just have to find the correct valve layout...
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Out of interest, did you designed the hw yourself.
From the look of the PCB it didnt look like homebrew to me, more like a mass produced board already.
I see it has an IR remote sensor. Do you have a pic for the remote handset?
I have a ford too and attest to the vaccum switch. but i think what the purpose of the project is a bit more basic then total HVAC controlls.
