Page 56 of 56 FirstFirst ... 64647484950515253545556
Results 551 to 558 of 558
Thread: HVAC Control on Car PC through Serial Port.
  1. #551
    Oct 2006
    Las Vegas
    Quote Originally Posted by Civic Modz View Post
    Ok, so you dont want to use a PC. You want an independant climate control but just utilizing the buttons/knobs and LCD of an Audi right? Most modern climate devices are quite complex the use numerous sensor in the cabin and engine bay. For example my brother has an 96 quattro, if you turn on the heater the fan will not turn on until the engine is warm enough. To utilize the same electronics in the audi controller you would have to get all the sensors that are used including any additional outputs. If you have a look at the connector of the climate I assume you might find about 20+ wires connected to it. Its possible but a big job (a schematic or wiring diagram will make it a bit easier). An easier way is just to use the dials and buttons of the audi and interface them to you climate system. This way you would be bypassing all the electronics from the audi (you would loose the LCD, unless you add your own or work out how to control the original one). Post a pic of your climate system in your car.
    I can support that statement, I've been at it for a while. In fact, I've been sitting here tonight working on converting both an automatic and manual version of a factory climate control head to schematic, to ensure my tie in points and methods will work properly. It gets pretty complex. Like this particular circuit I'm tracing has this votage divider circuit used in the A/C compressor request line that takes the input from the intake temp sensor and compares it to a reference current. The connectors on the back total 36 pins.
    Good luck with the project, unfortunately for you most of what you'll find here is PC related interface ideas and implementations.... I still wonder what happened to Mastero.
  2. #552
    Jul 2007
    i dont necessary want to keep the display or the auto c/c etc all i want to do is press a button n the vents mova accordingly
    this is what i have
    http://cgi.ebay.co.uk/Vauxhall-Caval...3286.m20.l1116
    - the aircon and recirc buttons, car don't have air con :-(
  3. #553
    Sep 2005
    Australia
    How many of the controls are cable driven. Since the most difficult part of this would be to make up a custom bracket and mount a servo on it, so it can control your vents. Thats what I ended up doing. I was lucky though for me there was a nice spot to put the bracket and servo. I'd recommend you to somehow connect a servo to these cables first. Controlling them is not that hard. Or you could check to see if a later model of your car has motor control and you might be lucky and you could mount the motor to the cable control.
  4. #554
    Dec 2007
    Boulder, CO
    Just a little follow up... has anyone heard from this guy? I found his website and thought the product was layed out quite nicely... then I come on here and see that no one has heard from him. Makes me wonder about ordering. So whats the latest?
    Also, if there is another direction, I'm looking for a complete HVAC solution for my 2000 BMW Z3. I'd like something that already has software which I can tweak and embed in RR and mod a skin to become a 'tall' skin leaving room at the bottom for the hvac controls to always be viewable/accessible (or something along these lines...)
  5. #555
    Sep 2005
    Australia
    Hmm yeah, Mastero seems to be gone. You might be able to email him from his site, but dont quote me on that If you want an alternative direction have a look at the Fusion Brain thread. Its smaller and more supported.
  6. #556
    Dec 2007
    Boulder, CO
    Thanks Civic Modz!
  7. #557
    Jul 2007
    Is this device still available, or one like it? I clicked on the link in the first post, but the page wasn't reachable.
  8. #558
    Apr 2008
    Austin, Tx
    Quote Originally Posted by jjohnston View Post
  1. Using PC to control lighting.
    By gguy in forum General Hardware Discussion
    Last Post: 10-16-2007, 07:11 PM
  2. Kenwood In-dash Monitors to control pc?
    By DrBuzzo in forum LCD/Display
    Last Post: 12-08-2004, 07:21 AM
  3. cd changer control to control the pc
    By babas151 in forum General Hardware Discussion
    Last Post: 10-25-2004, 11:21 PM
  4. software to control pc from ipaq
    By spud42 in forum Software & Software Development
    Last Post: 11-13-2001, 12:56 AM
  5. Using a pda to control a normal PC
    By All4Norway in forum General Hardware Discussion
    Last Post: 08-27-2000, 07:52 AM
