Page 7 of 56 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 558
Thread: HVAC Control on Car PC through Serial Port.
  1. #61
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    The fan speed is not controlled by vacuum in my ford. It controlles where the air flows...foot/face/defrost
    There is a mechanical switch to controll the fan speed
  2. #62
    Apr 2005
    Quote Originally Posted by Chris31
    I think alot of poeple will have problems attaching a servo/actuator to the control knob/shaft.
    The controller must know how much to turn the servo/actuator by as well as how many stop positions. Attaching and mounting the servo can be a problem to most, non of them would be standard the way they work.
    Not to put off you guys, I can just see problems comming in making a universal AC controller...it can be done though.
    Take the knob off and attach one of these to the shaft:
    Servo Shaft Adapter
    Servo's are meant to be fairly precise (digital ones even more so) so getting them to go to the appropriate position isn't a problem.
  3. #63
    FLAC Mastero's Avatar
    Aug 2001
    India
    Quote Originally Posted by antimatter
    That is what i am trying to say .... this device will not change the air folw direction...
    If i am correct then the vacuum system controls the flow of air.. in some cars they use cables for that .....
    This unit just controlls the fan speed and the compressor.
    I hope this clears things ..
    Mastero
  4. #64
    Jan 2004
    California
    Quote Originally Posted by Mastero
    Mastero
    but i think what the purpose of the project is a bit more basic then total HVAC controlls
    As i mentioned earlier your device is not an HVAC solution but more of AC solution. I think others in the thread were getting confused about this. Any way you look at it good work!
  5. #65
    Aug 2001
    India
    I know ... taught so too ...
    Mastero
  6. #66
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by White Night
    Servo Shaft Adapter
    That is cool and all, but doesn;t solve the problem. The Motot must be mounted to something so that it doesn't. Attaching the shaft adapter to the shaft of the control knob for the AC will just have the motor protruding into free space.
    Michael
  7. #67
    Apr 2005
    Quote Originally Posted by Wiredwrx
    Michael
    That's true. There are a variety of ways to mount the servos. The best depends on the layout of the knobs. On my Jeep, a small hardware store bought angle bracket, some wood, and these little 90 degree mounts did the job. Mounting the servo turned out the be the easy part. Figuring out how to best connect them to the shaft took the research.
  8. #68
    Jan 2004
    California
    The hard part for me would be controlling the servo with the PC. It would take software and hardware working together. I have no experience with this. It would be nice to have HVAC controled by the PC but thats not what this thread is about.
  9. #69
    Registered User
    May 2003
    RC servo operates on PWM. If the knobs have 3 position, all thats needed is to find out whats the PWM values are to get to those 3 position.
    For simplicity sake,
    A 555 timer is used to generate the PWM. (Circuit can be found easily by googling)
    3 variable resistor each defining the position of the servo can be used. One of the variable resistor is switched into the 555 timer by means of the bits from a parallel port.
    Again, to make thing simple small reed relay are used to switch the variable resistors into the PWM circuit...moving the servo to the required position.
    Its a ghetto way for non so techie poeple. Should work as well.
    Ill never do it this way though
  10. #70
    Registered User
    May 2003
    The servo-knob shaft adaptor is cool. I think its the filing/drilling/bending/glueing metals that might put off poeple from buying a servo driven kits.
    I guess theres no other way though for such a system.
  1. Using PC to control lighting.
    By gguy in forum General Hardware Discussion
    Last Post: 10-16-2007, 08:11 PM
  2. Kenwood In-dash Monitors to control pc?
    By DrBuzzo in forum LCD/Display
    Last Post: 12-08-2004, 08:21 AM
  3. cd changer control to control the pc
    By babas151 in forum General Hardware Discussion
    Last Post: 10-26-2004, 12:21 AM
  4. software to control pc from ipaq
    By spud42 in forum Software & Software Development
    Last Post: 11-13-2001, 01:56 AM
  5. Using a pda to control a normal PC
    By All4Norway in forum General Hardware Discussion
    Last Post: 08-27-2000, 08:52 AM
