Page 8 of 56 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 558
Thread: HVAC Control on Car PC through Serial Port.
  1. #71
    FLAC Mastero's Avatar
    Aug 2001
    India
    Quote Originally Posted by Chris31
    RC servo operates on PWM. If the knobs have 3 position, all thats needed is to find out whats the PWM values are to get to those 3 position.
    For simplicity sake,
    A 555 timer is used to generate the PWM. (Circuit can be found easily by googling)
    3 variable resistor each defining the position of the servo can be used. One of the variable resistor is switched into the 555 timer by means of the bits from a parallel port.
    Again, to make thing simple small reed relay are used to switch the variable resistors into the PWM circuit...moving the servo to the required position.
    Its a ghetto way for non so techie poeple. Should work as well.
    Ill never do it this way though
    Chris ... i can free two LPT bits ... so say we can have two servo control. the bits can be timed pluse or always on ...
    If the 555 timer can be designed so the each pluse on the trigger will change the servo position that shall be nice.
    Meaning if you hit the trigger with one pluse the servo will move to x position and stay there, then when you hit the pluse again the servo will move to y position and stay there.. so on ..
    You think you can put the design on paper? for the 555 timer
    Let me know.
    Then we can use two of this to control the vents and the air circulation
    mastero
  2. #72
    Registered User
    May 2003
    Quote Originally Posted by Mastero
    Of course it can be done that way but how is the PC able to track where the servo is currently at?
    Use 2 bits from the parallel port to provide the position.
    00 = OFF position
    01 = 1
    10 = 2
    11 = 3
    This way the PC always know where the servo is.
  3. #73
    Aug 2001
    India
    That can be done ....... waiting for the hardware design chris..?
    Mastero
  4. #74
    Registered User
    May 2003
    Mastero
    Waiting for whos design?
  5. #75
    Aug 2001
    India
    I taught you had the design .. in mind ......do you ...?
    Mastero
  6. #76
    Registered User
    May 2003
    No, it just a thought that I reckon that can be done quite easily.
    Search for 555 timer servo PWM control or something.
    Then just use a small relay to switch the potentiometer in the circuit...or better to use an electronic switch. Then just control the switch by the parallel port.
    Pretty much job done really.
  7. #77
    Registered User
    May 2003
  8. #78
    Aug 2001
    India
    chris i know the 555 and the 556 generates PWM
    but my concern is how does one change the servo position from x to y to z using the same trigger .. and not changing any hardware
    mastero
  9. #79
    Registered User
    May 2003
    Ok use 74HC4016 or 74HC4066. It contains 4 electronics switches, controlled by individual lines.
    You need to control 1 of the 4 lines by another chip.
    The 74HC4017 is a clocked decimal counter. Use the reset line when the output reach 5.
  10. #80
    Aug 2001
    India
    Ok chris lets not just add posts to this thread.....
    Can you put your idea on paper ...
    Mastero
  1. Using PC to control lighting.
    By gguy in forum General Hardware Discussion
    Last Post: 10-16-2007, 08:11 PM
  2. Kenwood In-dash Monitors to control pc?
    By DrBuzzo in forum LCD/Display
    Last Post: 12-08-2004, 08:21 AM
  3. cd changer control to control the pc
    By babas151 in forum General Hardware Discussion
    Last Post: 10-26-2004, 12:21 AM
  4. software to control pc from ipaq
    By spud42 in forum Software & Software Development
    Last Post: 11-13-2001, 01:56 AM
  5. Using a pda to control a normal PC
    By All4Norway in forum General Hardware Discussion
    Last Post: 08-27-2000, 08:52 AM
