Here you go...
This is according to your spec I hope.
You just need to sort out your own wiring according to the chips you want to use.
...a single 12C508 would sort it all out.
Originally Posted by Mastero
You know, I really expected you to susse out what I was talking about...considering you been designing a far more complicated hw that this.
OK, Ill draw it for ya but I still need to add post to this thread, how am I supposed to show you what I drawn on paper![]()
Here you go...
Originally Posted by Chris31
hehehe i was just seeing this from a different way .. more like software based ...
a servo signal line requires a pluse to work
0.6m Sec -45 degrees minimum pulse length
1.5m Sec 0 degrees center position
2.4 mSec -45 degrees maximum pulse length
so why cant we just add make vb send the pluse through LPT port ..?
This way we can control the pluse and servo angle...
Would love to see your hardware design also ...
Mastero
PS : It always takes more than one person to create something.
I know its unreliable ... just a taught ...Originally Posted by Chris31
I dont think it will work ... VB timer does not allow 1.5![]()
Ok back to the drawing board....
Mastero
Chris is there a way to read the code from a CP PIC .....??
Mastero
If you are interested in doing it, there's really not much to it. For $25 you can get a USB Servo controller that can be controlled using Visual Basic (or VB Script for that matter) with a few lines of code.Originally Posted by antimatter
Phidget Servo Controller
In addition, the board handles all the processing so you wouldn't be sucking up valuable CPU cycles with timers and what not. Also, I realize this thread isn't about a complete HVAC system, so I won't say anything else about it. Just wanted you to know it isn't to hard to do if you were so inclined.![]()
Used to do it on old 16C84. I doubt it very much if you can do it with the new chips.Originally Posted by Mastero
Its been read protected for a reason.
I know its for a reason.. the chip i am looking at is 16F72 is there a way for it ...?Originally Posted by Chris31
Mastero
