FYI: Dylan makes Earth Bridge, David makes GooPs.
Thanks spaceskater,
Can you capture and send me the nmea output when the problem occurs? If not I can make a special debug build for you to run.
Very true! Sorry about that David! I mixed the names up... I'll capture and send you the nmea output as soon as possible! Thanks!Originally Posted by RPM_VR4
Will never be DONE! There is always something to add
VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
spaceskater,
Did you try the <RotateMinimum> setting in Autozoom.cfg for your spinniing problem?
I don't think I have any control over that dialog that comes up when Google Earth starts. I believe you can ignore it and it will go away on its own once Google Earth gets started.
I can add a setting to autostart GE when GooPs is launched.
Thanks again.
Originally Posted by spaceskater
just what i was going to ask for!Originally Posted by davidhite
or is there some way to embed GE in some window in goops
atm ive got it embeded with skinbedder..
I wan't a demo of GooPs that goes from stopped to 80MPH to stopped again. It is possible to save a demo with a .KML log and have it play them with the current autozoom.cfg file so I can fine-tune it?
I got some NMEA data! How can I send them to you? email? Total about 800KOriginally Posted by davidhite
Well GE is not open yet when I get the message... I thought it was Goops ServerOriginally Posted by davidhite
Thanks David
Thanks spaceskater - email to mygoops@gmail.com.
spaceskater,
It looks like some of your nmea GPRMC heading data is incorrect. GooPs does a sanity check and discards any sentences that contain invalid data. In your case many of the GPRMC sentences contain negative heading values. This will cause GooPs to appear to stop tracking. I'll have GooPs update the status bar to read "Invalid data received" when this happens. I think the other problems you see are coincidental.
...very strange. Why is his GPS device outputting invalid data? Is it correct if you take away the negative? Maybe you should just ignore the negative for greater device compatibility (even if those devices are technically sending invalid data).
Anyway, I got a question and some feedback for you:
First off, how can you set the refresh to less than 1 second in GE? I could have sworn you told me I should be able to do that through GE, but it does not support decimals (or 0 seconds). Can you edit the registry setting manually or something?
Now on to the bug: Auto-zoom doesn't really seem to trigger all the settings properly. Sometimes it will show the picture of one speed with the angle of another, or the zoom-level. All settings interchange a bit. This makes my pictures (top/rear/default-arrow) not really match up with the zoom/tilt levels. If you make 3 or 4 line config file with all the settings drastically different and negative with different pictures you should be able to see what I mean. If you (don't)use the -'s properly you can get it to work ok, but I don't understand why it wouldn't work with all -'s.
Feature Request: Can you make the two images morph when not using negatives (jk, lol).
