Page 18 of 72 FirstFirst ... 891011121314151617181920212223242526272868 ... LastLast
Results 171 to 180 of 717
Thread: GooPs Real-time GPS Tracking and Navigation for Google Earth -Version 2.5.13 Released
  1. #171
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by RPM_VR4
    ...very strange. Why is his GPS device outputting invalid data? Is it correct if you take away the negative? Maybe you should just ignore the negative for greater device compatibility (even if those devices are technically sending invalid data).
    He's got a OEM dead reckoning setup. Its still in the beta stages, especially when he looses the SATs.
  2. #172
    Variable Bitrate davidhite's Avatar
    Feb 2006
    Thanks for the feedback and suggestions RPM,
    I'll try to have GooPs be more tolerant of bogus data. Throwing the sentence away was a lazy work-around for another problem I was having.
    I'm working on your play/record capability now.
    You can't actually set the refresh interval to less than 1 second. The trick is to set the Time-Based refresh to "Periodically" - "1 second" and the View-Based refresh to "After Camera Stops" - "0 seconds". This gives you a non-deterministic refresh of 1 second or less.
    Would you please send me an AutoZoom.cfg that exhibits this behavior?
    I'll get right on morphing those images .
    Anyway, I got a question and some feedback for you:
    First off, how can you set the refresh to less than 1 second in GE? I could have sworn you told me I should be able to do that through GE, but it does not support decimals (or 0 seconds). Can you edit the registry setting manually or something?
    Now on to the bug: Auto-zoom doesn't really seem to trigger all the settings properly. Sometimes it will show the picture of one speed with the angle of another, or the zoom-level. All settings interchange a bit. This makes my pictures (top/rear/default-arrow) not really match up with the zoom/tilt levels. If you make 3 or 4 line config file with all the settings drastically different and negative with different pictures you should be able to see what I mean. If you (don't)use the -'s properly you can get it to work ok, but I don't understand why it wouldn't work with all -'s.
    Feature Request: Can you make the two images morph when not using negatives (jk, lol).
  3. #173
    Constant Bitrate spaceskater's Avatar
    Feb 2005
    Boston,MA
    Quote Originally Posted by davidhite
    spaceskater,
    It looks like some of your nmea GPRMC heading data is incorrect. GooPs does a sanity check and discards any sentences that contain invalid data. In your case many of the GPRMC sentences contain negative heading values. This will cause GooPs to appear to stop tracking. I'll have GooPs update the status bar to read "Invalid data received" when this happens. I think the other problems you see are coincidental.
    That is interesting. I guess that explains it but why would the navigation programs work with no problem? I assume the Dead Reckoning generates the unexpected values. Possibly the Nav programs ignore the invalid sentences?!
    Thanks for your help David. Wile you're at it could you add the GE auto start future when Goops load? One more suggestion - request: When you auto load GE then wait for some time (about 30 secs or a custom value on registry?) and then add the Goops server to the program so that we avoid the error dialog I get when Goops starts GE? That would allow me to have a button in my front-end (Frodo Player) that loads Goops and then embeds GE automatically.
    Will never be DONE! There is always something to add
    VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
  4. #174
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Space: GooPs does (optionally) auto-load GE when you start the demo or connect to the GPS. If you enable auto-connect to GPS, it should auto-load GE immediately. Also, what error dialogue do you get? You should not save your temporary places when you exit GE. If you do not have any GooPs server in your "My Places" then you should not get any error.
    David: Just make something like this:
    Code:
    0, -2000, -80, pic.png, -.5
    5, -500, -45
    25, -3000, -60, pic.png, -.75
    45, -8000, -75
    You should see it mixing pics and zoom levels where it shouldn't.
  5. #175
    Feb 2005
    Boston,MA
    Code:
    5, -500, -45
    45, -8000, -75
    Well auto start has never worked for me in any of my 3 computers so i guessed it is not relevant to my pc. I figured that auto start was that when you clik Add/Update in the settings it starts GE. Does it work for you?? When you start GooPs it automaticly starts GE? I always have autoconnect in the GPS and it does autoconnect but that's it, not GE.
    Also the problem I metioned before is that when goops tries to auto start GE I get this error (see Photo). It is a bit annoying since i have to click on retry when GE starts so it will go away.
  6. #176
    Feb 2006
    Thanks for the example RPM.
    I think you may be confusing the "Eye alt" in GE and the range in AutoZoom.cfg.
    The range in AutoZoom.cfg is the distance from your "eye" to the cursor. It's not the same as the "Eye alt" in the bottom right of the GE view. "Eye alt" is the altitude of your "eye" relative to sea level, so it will vary depending on your current tilt and the elevation of the cursor.
    To see this more clearly, turn off "Tilt" in GooPs and set it manually in GE so you are looking directly down on the cursor. The "Eye alt" should now read the current range (from AutoZoom.cfg) plus the elevation of the cursor above sea level.
    I did see a speed rounding error in the GooPs AutoZoom config stuff. For example the 45-55 mph row is used when the speed is between 55 and 55.4 (or maybe 55.9).
    I didn't see any problem with GooPs using the wrong images based on speed (except for the rounding problem). Perhaps you were expecting the image to change based on the "Eye alt" in GE?
    Currently GooPs only autostarts GE when the "Start Demo" button is pressed or when the "Add/Update" button is pressed in the "Options" dialog. I'll have to see if I can find a workaround for the switch/retry dialog problem.
    Having a GooPsServers in your My Places folder shouldn't have any effect on whether the dialog comes up.
    Code:
    5, -500, -45
    45, -8000, -75
  7. #177
    Nov 2004
    L.A.
    David: You should make it so whenever the GooPs network link is active (either running demo or recieving GPS data) it checks to see if GE is running and launches it if it is not (I thought that was how it already worked because I don't have it in my car yet and was only using demo so far - my whole CarPC is broken right now . Also I have never seen that strange error message).
    I do understand that elevation is reduced by tilt-angle. I was definatly seeing it mix zoom-level and pictures incorrectly though. For example, my 0-5 is a top view (tilt=80, zoom=2000) with a picture of the top of a car. My 5+ is close a rear view (tilt=50, zoom=500) with the picture of the back of a car. Sometimes I would see the top-picture of the car even though the tilt was 50 and the zoom was 500. This makes my car look tiny and like it is blasting off in to space instead of driving on the road (LOL).
  8. #178
    banned - scammer 97GST's Avatar
    Mar 2006
    Tijeras, NM
    I'm guessing i'm just stupid, I downloaded Goops, and all it is is some tiny program with a few small buttons. Do I need google earth also? and if so, is there any way around the 400 dolor subscription?
  9. #179
    Feb 2005
    Boston,MA
    Quote Originally Posted by 97GST
    Yes you need Google Earth to use Goops. What Goops dose is that it read the NMEA data from your GPS and basically projects your location live in Google Earth. BUT Google Earth is FREE!!! No $400 subscription. Just go here and download. http://earth.google.com/download-earth.html
    Only the Pro version needs subscription.
  10. #180
    Mar 2006
    Tijeras, NM
    So would this be a good GPS Tracker/Maping software that I could use in my car to get directions somewheres and alla that?
  1. iDrive - btbe's original version
    By btbe in forum RR Skins No Longer Supported
    Last Post: 06-11-2007, 11:58 AM
  2. Windows Mobile Smartphone Beta testers needed
    By zorro in forum PhoneControl
    Last Post: 02-23-2006, 08:57 AM
  3. WANTED: Phoco BETA testers for RR...
    By guino in forum Road Runner
    Last Post: 12-05-2005, 11:05 AM
  4. Looking for beta testers for new DC-DC PSU
    By MikeH in forum Power Supplies
    Last Post: 05-18-2004, 03:22 PM
  5. Wanted: beta testerss for X-MP3Pad (formerly MP944)
    By PorscheMP3 in forum Software & Software Development
    Last Post: 05-07-2002, 12:58 PM
