I'm assuming you have basic network connectivity from your home system to your carputer (a host name or IP address).
To configure on your home system (only need to do once, GooPs will remember your settings)
Start GooPs
Open the "Options..." dialog
Type any name in the "Name:" box (example "MyCar")
Type your carputer's host name in the "Host:" box.
Click "Add/Update GE" (Google earth will start if it isn't already running)
Press "Ok"
Make sure "MyCar" is selected in the GooPs main window combo box.
Google earth will now show and track your car.
Once your carputer is entered in your home system all you have to do is select it in the Main window. GooPs will track to whichever name is selected in the main GooPs window.
Notice you can use all of the native google earth navigation features while tracking.
On your carputer:
Start GooPs
Unselect "Demo Mode"
Select the correct Port and Rate for your GPS.
Press "Connect" (connects to your GPS)
That's it
To track yourself on your carputer Just select "GooPs" on the main GooPs window. You can change the name from "GooPs" to whatever you like in the Options dialog. The host "localhost" is your local system.
LinkBack URL
About LinkBacks
