GooPs doesn't seem to work with ports above COM9:. I haven't heard of anyone else having a problem with GPS gate.Originally Posted by djmickyg
You're right djmickyg, I'm not able to open a com port above COM9:, I'll have to look into it.Originally Posted by djmickyg
Regarding the error message - does this happen when you start Google Earth? Try removing the GooPsServers link from the Google Earth Places folder, GooPs will create the link in the Temporary Places folder when needed. When you exit Google Earth don't save the Temporary Places when It prompts you.
Thanks for the feedback Naoziro. I'm glad you're enjoying GooPs.
Good suggestion, I'll put it on my list.Originally Posted by Naoziro
I don't believe this is possible using NMEA, but I'll look into it.Originally Posted by Naoziro
"GPS:Receiving Data" appears when GooPs successfully opens and reads anything from the COM port (could be garbage, could even be the wrong COM port). You're right, I need to improve the connection status to help debug this problem.Originally Posted by Naoziro
I hope this isn't happenning all the time for you. I have seen this on occasion when using GooPs with my laptop. Pressing the "Connect" button in the GooPs "Options" dialog sometimes helps. Sometimes I have to stop and restart GooPs.
Sounds like a bug. GooPs saves it's track data between invocations, so it should only happen when it runs for the first time and has no saved track data. It can also happen if GooPs can't find it's saved track data.Originally Posted by Naoziro
RPM_VR4 is working on this.Originally Posted by Naoziro
Thanks for your comments Naoziro. Great feedback like yours helps make these apps better for everyone.Originally Posted by Naoziro
its alright.. i changed my virtual ports down below 10..Originally Posted by davidhite
i will try playing around with the temp folder. thanks
I found the problem with using COM ports above COM9. Microsoft has a "special" syntax. For COM ports COM10 and higher you must precede the name with "\\.\" (e.g. "\\.\COM10"). Talk about random <g>. I'll have a fix ready in the next day or so.
Used your program while driving home today... just gotta say holy crap this is impressive!
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
Thanks PURDooM,
I appreciate your feedback!
1.7.7 – 6/12/06
Fixed problem opening ports above COM9.
Enhanced GPS connection sequence messages.
1.7.7 – 6/12/06
Google Earth 4.0 Beta released today.
Ran a quick test and it appears to work fine with GooPs.
Improved road/street name display (no annoying flickering when view moves)
Supports textures on 3d objects (this is awesome, but requires mucho CPU with directx, haven't tried with OpenGL).
Improved/simplified UI
