Page 25 of 72 FirstFirst ... 151617181920212223242526272829303132333435 ... LastLast
Results 241 to 250 of 717
Thread: GooPs Real-time GPS Tracking and Navigation for Google Earth -Version 2.5.13 Released
  1. #241
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Awesome. I tried out Beta 4.0 yesterday as well. Too bad they don't have pre-loaded textured buildings... you have to download the KML on a per building basis. I can't wait till they have all of downtown LA textured!
    I've moved and had lots of other work, but I haven't given up on the Sb skin. My next version will have buttons that switch views by changing the .cfg file while in-use. It will be awesome!
  2. #242
    Variable Bitrate davidhite's Avatar
    Feb 2006
    New Google Earth Cacheing App
    njwashor is working on a Google Earth cacheing app. Could be very handy.
    http://mp3car.com/vbulletin/showthread.php?t=78873
  3. #243
    Nov 2004
    L.A.
    Hey David, you still around and programming?
    I'm not sure if you are up to this, but I realized today the best way to use GooPs as a nav system... don't .
    iG3 + GooPs together would work perfect if we could only integrate them together. The top-view in iG3 sucks! It places your car on the bottom of the screen so if you have any turns you have to zoom out a ton to see the full path. Sometimes you can change from heading to north, but it's still no zoomed out Google Earth. Conversly, GE sucks when zoomed in as you don't get the "hybrid-view" road overlays.
    I just always use iG3 in 3D/Heading view to show me turns and announce turn-by-turn directions. I'd rather use Google Earth if I want to look at a map should I decide to stray from my route a bit. iG3 will recalculate and keep giving me it's directions as I modify its path my driving an alternate route with GooPs map as my guide.
    ...so here is the software request: Make it so whenever I choose a destination in iG3, GooPs automatically routes it's own driving directions from the current GPS location to iG3's destination. This way I have the route highlight in both programs, an awesome map with traffic conditions overlayed in GooPs, and turn-by-turn directions from iG3.
    If you would like to be on-board but do not know how to get a route from iG3, maybe I could do that part and you could just make it so when GooPs receives a window message with co-ordinates (or an address) from my app, it automatically routes directions from the current location to those co-ordinates in Google Earth.
    Possible?
  4. #244
    Nov 2004
    L.A.
    I almost have a new skin done for GooPs, but I have been having a lot of problems trying to use it with the new GE4 Beta2. The icons do not work, I get the default placemark icon instead.
    Are you working on an update?
  5. #245
    Nov 2004
    L.A.
    GE Nexus Released: RELEASE: GE-Nexus (for GooPs / Google Earth in CF Nexus)
    It does not work with GE 4 beta though. I can't wait for an update!
  6. #246
    Feb 2005
    El Paso, TX
    Dumb question.. I just found put about this and it's a great idea.... But I still do not understand the way to "make it work". I was able to run and saw "me" with some other guys at Oregon, but what I do not get is how to setup up your pc to make it work. Now, I do have the GPS receiver in the car but I do not have internet access in my car. So how exactly does it track it? via the GPS receiver? I mean, how do I setup my carpc to the GooPs to make it work? I re-read many times the first threads and I just could not make it work. Thanks
    Israel
  7. #247
    Nov 2004
    L.A.
    Click the [Options...] button in GooPs. Then turn off Demo mode and select the COM port for your GPS. After that it will follow your GPS instead of "Me*" and those other guys in the demo.
    As for internet, it will work without it, but it will just all be gray instead of images. You kinda need internet in the car for it to really work. Google Earth does allow up to a 2GB cache (or more if you reg-hack it), so some people have built up the cache by flying around the places they drive on their home computer, and then just transfer the cache file to the CarPC.
    Depending on where you live, you may be able to get internet in your car for $20/mo or less (search the forum).
  8. #248
    Aug 2006
    Remote Tracking
    So guys ... IS there a solution for how to track others via internet.
    I saw the solutiuon of FindMe FindU and it is basedon submitting the info to a server where u can track. The server will also generate a KML file allowing tracking via EG as well.
    Is here a similar solution found?
    P.S. GPSGate (Franson) add also a plug in for EG ... is working but all users need
    GPSgate to use the tcp/ip gate ....
    Salem
  9. #249
    Nov 2004
    L.A.
    What?
    GooPs only tracks if you are on a LAN (have a static IP).
    Try GPS Secure and/or WhereIsMyGPS (both have their own sub-forum in the "support software" section).
    EDIT: Is FindU just for amature radio? No GPS/Internet support?
    Also, you may want to look at mologogo.
  10. #250
    Aug 2006
    Take a look at this one to see what I meant by FindU.
    http://jprestonsystems.2mydns.com/wr...0&lineson=True
    For more info:
    http://www.geocities.com/prestonsystems/mytracking
    Anybody can track me or those who are in the list.
    I have a tiny program installed in ppc sending coordinate to the server.
    also a link to kml file is provided.
    I like to have the combi of GooPs and FindMe where real-time tracking with EG.
    I know that GooPs allow only those who are visisble in the network .. my question was more: how to?
  1. iDrive - btbe's original version
    By btbe in forum RR Skins No Longer Supported
    Last Post: 06-11-2007, 11:58 AM
  2. Windows Mobile Smartphone Beta testers needed
    By zorro in forum PhoneControl
    Last Post: 02-23-2006, 08:57 AM
  3. WANTED: Phoco BETA testers for RR...
    By guino in forum Road Runner
    Last Post: 12-05-2005, 11:05 AM
  4. Looking for beta testers for new DC-DC PSU
    By MikeH in forum Power Supplies
    Last Post: 05-18-2004, 03:22 PM
  5. Wanted: beta testerss for X-MP3Pad (formerly MP944)
    By PorscheMP3 in forum Software & Software Development
    Last Post: 05-07-2002, 12:58 PM
