Page 32 of 72 FirstFirst ... 222324252627282930313233343536373839404142 ... LastLast
Results 311 to 320 of 717
Thread: GooPs Real-time GPS Tracking and Navigation for Google Earth -Version 2.5.13 Released
  1. #311
    Variable Bitrate davidhite's Avatar
    Feb 2006
    Thanks Thomas,
    That's good to hear. I've been putting in some extra error checking to try to figure out what might be happening on the GooPs side.
    Quote Originally Posted by FlyingsCool View Post
    Hi David,
    Good news. I went driving today for well over an hour and didn't have a single problem. The main difference is that I rebooted the PC in between last night and today. So perhaps there was an instability or something in the Bluetooth connection or somewhere else.
    Thanks!
  2. #312
    Feb 2006
    I'll experiment with that idea and see how it goes.
    One more request:
    Would you be averse to creating a new viewpoint, "In the vehicle". It wouldn't be much use in a car, but I think it would be helpful for aircraft.
    BTW, I like John Murray's suggestion about varying the width of the track based on a variable. EXCELLENT idea.
    Thanks!
  3. #313
    Feb 2007
    Groton, MA
    You may already be aware of this, but, just in case, you may want to check out a program called MyFSGoogleEarth http://www.elbiah.de/flusi/MyFsGoogl...oogleEarth.htm
  4. #314
    Feb 2007
    This is the third try; the other posts disappeared.
    Again thanks to davidhite for considering incorporating variable track widths into GOOPS. FlyingsCool's lead to the I.TrekZ1 Bluetooth GPS receiver and 8MB data logger is also very interesting.
    I've had no luck connecting to the embedded GoogleEarth Pro GPS with non-supported Trimble and CMC receivers (trying the Magellan serial selections). Considering the GE 100 point track limit that is insufficient for all but short or small projects; probably nothing is lost by not pursuing that possibility. Thats why I see promise in GOOPS; where I have had no problem connecting to a CMC receiver; and expect no trouble with Trimble equipment.
    I didn't mention my Motorola Canopy wireless network I have deployed by tying Motorola access points to Belkin N routers 2 to 4 miles apart. I've got 1 to 3 MB/sec download speeds after three hops and at a distance of 10 miles. I can't wait to get Google Earth, GOOPS, the wireless internet communicating to the web and BlueTooth GPS all working together. Thanks. We all benefit by sharing experiences.
  5. #315
    Feb 2007
    Groton, MA
    As far as interfacing and com ports, you may find the following links useful
    Freeware serial port bridge (and other) drivers:
    http://www.mixw.net/related.htm#tncemu
    Unfortunately, I was unable to get this to work with Goops (maybe you can)
    So I purchased from Eltima.com a very capable and easy to use but rather expensive SP Bridge (but comes with free 14 day fully functional trial):
    http://www.eltima.com/products/vspdxp/
    A freeware ethernet to serial port driver:
    http://www.hw-group.com/products/hw_vsp/index_en.html
    I haven't used this, but it looks interesting
  6. #316
    Feb 2006
    GooPs 1.9.2 - Built in FTP remote sharing, more control enhancements
    GooPs version 1.9.2 Release Notes
    Important: You must remove any existing "GooPsServers" network links from your Google Earth "Places" folder.
    Smoother navigation and control in Google Earth at all times.
    GooPs no longer "fights" you when you use the Google Earth navigation controls.
    Saved kml uses icon instead of 3d cursor.
    The icon will be automatically scaled now, unlike the 3d cursor.
    Various bug fixes around AutoView and error handling
    TimeStamps are no longer displayed near the cursor.
    This tended to obscure the cursor and was generally distracting.
    Added FTP client capability for sharing your location remotely.
    Requires an account on an FTP server (provided free by many ISPs). Periodically saves your location to an FTP server. The location can then be viewed via http by others with Google Earth or Google Maps.
    Here's my GooPs location via google maps:
    http://maps.google.com/maps?&q=http:...ps/ftptest.txt
    Interestingly, my ISP's http server won't serve files with the extension ".kml", that's why the file is named ftptest.txt (not ftptest.kml).
    Here's the kml for a network link that will track my GooPs vehicle remotely.
    This one updates every 8 seconds.
    <?xml version="1.0" encoding="UTF-8"?>
    <kml xmlns="http://earth.google.com/kml/2.1">
    <NetworkLink>
    <name>ftptest</name>
    <Url>
    <href>http://sites.onlinenw.com/goops/ftptest.txt</href>
    <refreshMode>onInterval</refreshMode>
    <refreshInterval>8</refreshInterval>
    </Url>
    </NetworkLink>
    </kml>
    There is currently a bug in Google Earth that does not allow you to ignore network link fetch errors.
    If you exit GooPs and restart it without closing Google Earth you must manually refresh the link. Right click on the GooPsServers Network Link in your Places or Temporary Places folder and select "Refresh".
  7. #317
    Feb 2006
    That's very cool. Do you think there is there a demand for this in the Flight Simulator community?
    I don't think it would be too difficult to put hooks in to GooPs to get it's location data from FS.
    I need to work on the "Air" mode in GooPs.
    Have you gotten GooPs to work with GPSout?
  8. #318
    Feb 2007
    Groton, MA
    Quote Originally Posted by davidhite View Post
    Yes, there is also another payware program called FS Earth (http://fsearth.fsutil.com/) that I have not yet tried.
    The problem currently is that running FS and GE on the same computer can really clog things up, and works best on a high end computer. I've been even running FSX and GE on one computer, an E6600/nVidia 8800 GTS with 2 GB of ram on a DFI Intinity 975/GX. The whole computer cost $2150 from scratch including the XP operating system from Newegg. But trying to run even FS9 and GE on my 1.86 Pentium M laptop with 2GB is pretty much useless (I used to do it no problem. It was slow but it worked. But GE seems to have gotten quite bloated in processor use with version 4). But if you have two computers, it works great.
    I have gotten it to work, but, in order to do it, I needed a serial port bridge since what you read from is com ports (see previous post outlining the solutions I have found). GPSout ships with a freeware serial port bridge from MixW. But I was unable to get that to work with Goops (perhaps because your minimum baud rate is 2400 and theirs seems to be fixed at 1200? I don't know). So I had to purchase a commercial serial port bridge, and, after much searching and testing, settled on the one from Eltima. All of the solutions out there seem to cost about the same. If you know of a better solution, please let me know.
    If you need exact instructions on getting it to work, please let me know.
    Or, and perhaps you might read directly from FSUIPC as MyFSGoogleEarth does? The MFSGE interface is pretty slick and I was able to connect to FS over my home network very easily (FS and MFSGE on one computer, GE on another computer over port http://IPAddress/Name:30080/...).
    For FSX, you may want to skip FSUIPC altogether and check out the MS SimConnect API. But, given that there is still a huge FS9 userbase, your best bet is probably to stick with FSUIPC for now.
    I've also got Goops and GE working with my BT-338 GPS receiver on a Motion Computing LS800 tablet for use in my car and in the air.
    So, to answer your question, yes, there is a demand out there for a good solution for use with Microsoft Flight Simulator (and there are a couple successful ones, although I don't think the author is supporting MFSGE anymore), and, yes, I have gotten Goops to work with FS and it works very well, thank you.
    Doing this allows me to experiment/practice how I might use GE/Goops while flying.
    Thanks!
  9. #319
    Feb 2006
    Thanks Thomas,
    I can set the minimum baud rate to 1200 or whatever.
    I worked on GooPs "Air" mode last night. There is a Google Earth bug that is preventing GooPs from setting the Focus Point altitude at anything other than ground level. Until this is resolved I can't really do any better than the current implementation.
    I am also working on the ability to select Google Sketchup models for the cursor. You can get very realistic car and airplane models at the Google 3D warehouse. I don't know if you can convert Flight Sim airplane models to Collada.
  10. #320
    Feb 2007
    I'm waiting for the new I.TrexZ1 BluTooth GPS receiver and Dongle to arrive so that my laptop is compatable. A serial to USB adapter should also show up soon so that Goops functionality can be shown in real time. Thanks
  1. iDrive - btbe's original version
    By btbe in forum RR Skins No Longer Supported
    Last Post: 06-11-2007, 11:58 AM
  2. Windows Mobile Smartphone Beta testers needed
    By zorro in forum PhoneControl
    Last Post: 02-23-2006, 08:57 AM
  3. WANTED: Phoco BETA testers for RR...
    By guino in forum Road Runner
    Last Post: 12-05-2005, 11:05 AM
  4. Looking for beta testers for new DC-DC PSU
    By MikeH in forum Power Supplies
    Last Post: 05-18-2004, 03:22 PM
  5. Wanted: beta testerss for X-MP3Pad (formerly MP944)
    By PorscheMP3 in forum Software & Software Development
    Last Post: 05-07-2002, 12:58 PM
