Page 41 of 72 FirstFirst ... 313233343536373839404142434445464748495051 ... LastLast
Results 401 to 410 of 717
Thread: GooPs Real-time GPS Tracking and Navigation for Google Earth -Version 2.5.13 Released
  1. #401
    Variable Bitrate davidhite's Avatar
    Feb 2006
    Quote Originally Posted by malathar View Post
    I don't think I asked my question the right way..
    When goops generates the kml for the file to be ftp'd. Is there a "template" or skeleton format that is uses to create the file or is the format hard coded into the application. The reason I ask is because I'd like to be able to edit or modify the template file to insert some image tags.
    I'm assuming at this point the kml output is generated from a hard coded layout in the application itself?
    You are correct, there is no template. Seems like there is some demand for a generalized way of inserting kml into the track at designated locations or frequencies.
  2. #402
    Apr 2007
    Quote Originally Posted by davidhite View Post
    Does demo mode work?
    If it does and the status bar says "Signal acquired" when you connect to your GPS you should be OK.
    Your GPS needs to be moving.
    You can check the "Enable debug log" box in the Options dialog, run for a minute, and send me the file goopsdebug.log
    You can get 3D models here.
    You need to read the instructions in the GooPs release notes on hte GooPs website to make them usable for GooPs.
    There is also a GooPs car model available here. It is ready for use.
    No, the demo didn't work. GE started automatically when Goops was started, but nothing happened in GE. Then, I changed the settings on Goops for GPS, then restarted Goops and GE. This time, Goops acquired the GPS signal, GE started, but, again, nothing happened in GE.
    Once I get a chance this week, I will play around with reloading GE as this might be the issue. I will also work through the trouble-shooting.
    Thanks.
  3. #403
    Apr 2007
    Appends
    Hi David thanks for the cool program! I have been using it to help my family track me as I drive from Chicago to Portland Oregon. I have had numerous issues come up on the road that perhaps you can help with.
    First I will describe my setup:
    *GPS Mouse reciever from Semsons using usb to serial com driver
    *Palm Treo w/Sprint Vision pack ($15/month) with PAM hack for laptop inet without paying bastard sprint $65/month charge
    *Built in XP dialup connection in network connections (to avoid unstable sprint connection manager)
    *PC laptop running Goops and google earth
    *150W power invertor to power laptop and tethered phone and mouse GPS
    1. The most important thing so far is appending to a previous trip, or how these record/stop pause/continue controls are supposed to work. I have not been able to keep a complete trip over multiple days with the server shutdown in the evening (turned off with me in the hotel).
    2. The name of the stored or preferred kml file does not persist through sessions. I have had to use the default Me.kml in the options, and then mirror this name in the ftp prefs to make it 'persist' without alot of typical pc pecking every time I use this.
    3. Save to local or ftp? How about both? Yes I want to serve this out, but the whole ftp thing is really volatile and my clients get a 404 half the time. When I check out my route in the evening out of the vehicle I am way bummed to see it has only grabbed my most recent segment with no detail from the previous days.
    4. How to properly shut this system down without losing data. Do I close Google earth first? Do I close Goops first? Either way, I get orphaned processes that requires me to reboot in traffic holding down the power button for 5 seconds to cold boot. End now, end now, end now...it might behave much better if I ditch google earth and just run Goops for logging...but then I have no feedback that the: NMEA gps feed is cool, that the FTP updates are working.
    5. How to Zoom out and stay zoomed out while centering. It keeps snapping back...
    Anyhow, it has been absolutely exciting for friends and family to watch my progress across the states - they even call to tell me I am driving too fast or which hotels to try...remote co-pilots I'm sorry if I have not read every forum post on this topic - with the move there were SO MANY things to prepare and getting this together is a miracle! This is a GREAT program and like others I would find this system complete if some route navigation/directions could be integrated. I have to run Mappoint alongside to keep an eye on exits etc - but unfortunately the GPS or comm port cannot be shared
    Hopefully I can beta test for you in the future and maybe you have some operational advice in the meantime - which I would truly appreciate though i am sure you are very busy.
    Thanks again so much!!
    -sleen
  4. #404
    Feb 2006
    Quote Originally Posted by sleen View Post
    -sleen
    Thanks for the great feedback sleen,
    I only have a minute right now, I'll respond more completely later.
    Always exit GooPs before Google Earth - this should solve your hanging process problem.
    Unfortunately record writes over the previously recorded file whenever it is pressed. I'll address that in a later release. You have to save the file manually if you want to keep it.
    You can set the number of points in the options dialog, but there is a limit at which GooPs will overwrite the oldest points with the new points (circular buffer). I believe it should go for about 8 hours before overwriting if your GPS is updating once every two seconds. You'll get more if you turn on compression.
    more later...
  5. #405
    Mar 2007
    David,
    Firstly, many thanks for developing a super app that really works a treat!
    However, I have noticed that with the latest release (V1_9_5) certain attributes within the autozoom config file are not supported;
    a) Cursor Image file
    b) Cursor Scalar
    c) The ability to change cursor image and scale as a function of speed.
    Also, it would be nice if the autozoom config file can support scalable 3-D model definitions for the cursor, similar to the image files currently supported, and the ability to select an autoview rotate perspective for a particular speed range.
    For the Marine and Aviation enthusiasts, a speed readout in Knots would be greatly appreciated.
    It appears that Goops does not save the state of the Cursor Image file on exit, and when next invoked the cursor remains invisble.
    Once again, many thanks for a great App!
  6. #406
    Feb 2006
    Quote Originally Posted by Abeh View Post
    David,
    b) Cursor Scalar
    Hi Abeh,
    Thanks for your feedback. You're correct, I broke the autozoom.cfg image stuff in that build. I'll fix it in the next release so that if you designate a cursor image in autozoom.cfg it will override whatever cursor settings are in the Options dialog (for the local vehicle only).
    I can't reproduce the problem with the cursor image file not being saved. If you are in "Demo Mode" nothing is saved. In normal mode (non demo) it should be saved.
    I've had the request for knots from several others. I'll put your other suggestions on the list.
    Thanks again.
  7. #407
    Mar 2007
    Disappearing Cursor Image
    Hi David,
    Many thanks for your kind cooperation in helping resolve the issues highlighted in my earlier post.
    However, once again I have looked into the earlier problem of the cursor image file not being saved on exiting Goops. This issue seems to persist outside of Demo mode (Normal Operational Mode), and I have tried a number of option with various different icons (.png image files) selected from the Pal2 palette within GE.
    I have to manually load the required cursor image file everytime GooPs is invoked. (Any input on this would be appreciated!)
    Thx again
  8. #408
    Feb 2006
    Hi David,
    Thx again
    Maybe I don't understand what you mean by "manually load the required cursor image". Do you mean select/enter the cursor image file from the GooPs Options dialog?
    -Dave
  9. #409
    Mar 2007
    Disappearing Cursor
    David,
    That's exactly what I mean;
    1) On Goops startup (everytime) need to go into OPTIONS , AND SELECT IMAGE, followed by the DROP DOWN DIALOG BOX TO INCLUDE THE REQUIRED IMAGE FILE
    Hope this explanation helps somewhat...
    Thx again
  10. #410
    Mar 2007
    Default startup location
    David,
    May I suggest that at Goops startup, if no realtime NMEA (GPS) data is being received, the default location should point to the last known position before Goops was last terminated (closed), rather than some obscure point in the south Atlantic off the coast of west Africa.
    Just a passing thought!
    Thx
  1. iDrive - btbe's original version
    By btbe in forum RR Skins No Longer Supported
    Last Post: 06-11-2007, 11:58 AM
  2. Windows Mobile Smartphone Beta testers needed
    By zorro in forum PhoneControl
    Last Post: 02-23-2006, 08:57 AM
  3. WANTED: Phoco BETA testers for RR...
    By guino in forum Road Runner
    Last Post: 12-05-2005, 11:05 AM
  4. Looking for beta testers for new DC-DC PSU
    By MikeH in forum Power Supplies
    Last Post: 05-18-2004, 03:22 PM
  5. Wanted: beta testerss for X-MP3Pad (formerly MP944)
    By PorscheMP3 in forum Software & Software Development
    Last Post: 05-07-2002, 12:58 PM
