Page 12 of 37 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 111 to 120 of 368
Thread: Laptop Auto Power-On / Turn-On Module
  1. #111
    Jan 2007
    Just read 15 pages of this section and keep seeing it said that I will still have to do the power button hack with the C1900 ???
    Is that right ?
  2. #112
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    Quote Originally Posted by Tapsell123 View Post
    Is that right ?
    Yes that is correct. The best solution is to use the plug / jack setup illustrated.
  3. #113
    Constant Bitrate mwmcginn's Avatar
    Dec 2006
    St Louis
    W3bMa5t3r,
    Got the module in the mail the otherday and everything looks good and well done but I have got a couple quick questions for you that may help others:
    Re: the mono jack,
    Does it have to be a mono jack? I am thinking not. I have a pretty tight place in the laptop that is the best place for me to put it. Can I just use another small 2 wire connector?
    Re: Multiple items,
    can you use the same module to switch two devices by splitting the 2 red leads? Id like to turn on the Lilli at the same time, can I just use the mono jack there and make two more leads going to my laptop?
    Mike M
    2006 Accord VP Sedan
    My worklog
    http://www.mp3car.com/vbulletin/work...-dads-car.html
  4. #114
    Apr 2006
    Quote Originally Posted by mwmcginn View Post
    W3bMa5t3r,
    Re: the mono jack,
    Re: Multiple items,
    can you use the same module to switch two devices by splitting the 2 red leads? Id like to turn on the Lilli at the same time, can I just use the mono jack there?
    You are correct, you can use any two conductor connector. I include the mono plug/jack because they're quick, cheap and easy to use. Everyone thus far hasn't had a problem, but you are by no means restricted to using them.
    I don't see why you can't use it for two devices, you would just have to split off the connection going to the laptop.
  5. #115
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    Ok so I decided to make my own module because i wanted power on working NOW and didnt want to wait.
    Let me tell you. GO ahead and buy it from W3bMa5t3r
    I already spent like 50 bucks making this. Just buying random things. And I still forgot the damn box to put it in.
    Switch $2, bought two different ones cuz one looked prettier at radioshack
    PCB $3 for two
    Relay 12v $5
    Relay 5v $5
    Relay 12v $5 Yes i bought another relay by mistake...
    Wire 100ft $8
    Wire 50ft $5
    Screw Terminal $3
    Resistors $1
    Capacitor $4
    Power Jack $3
    Power Plug $2
    and I still need to hack apart a usb cable(Have them) and a case($5?)
    radioshack/fry's sucks. Shoulduve just ordered them, or made a digikey order since I do need some stuff from digikey.
    The screw down terminals are being used as such.
    1 Screw terminal block is for usb
    1 Is for the power/ground
    1 is for the output switch/bypass switch
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
  6. #116
    Sep 2006
    Georgia
    forgot to mentian, tested, works great
  7. #117
    Apr 2006
    Quote Originally Posted by Ruffy View Post
    LOL glad everything is working for you. Building it is half the fun, and to be honest, yours is one of the better I've seen thus far from the folk building their own but thanks for the sales push lol. good luck with your project
    Cheers,
    Steve aka W3bMa5t3r
  8. #118
    Sep 2006
    Georgia
    Quote Originally Posted by W3bMa5t3r View Post
    Cheers,
    Steve aka W3bMa5t3r
    Yeah building it myself gave me a reason to bring out the soldering iron again. Fun times.
    still expensive buying locally. Forgot how much so. Could have cut cost in half if i shopped online for parts and waited
  9. #119
    Sep 2006
    Georgia
    quick question
    USB circuit keeps the relay forced on for a long period of time. Is this really safe for the life of the relay. whats the lifespan on them anyways?
  10. #120
    Constant Bitrate rsxtypes's Avatar
    Nov 2006
    Dallas, Tx
    There are probably HUNDREDS of relays in devices you use everyday. Infact, there are probably hundreds in your car already. These particular relays have no moving parts and should outlast your carputer and your car.
  1. Laptop Power On I've Searched Help Please
    By TimStark in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-28-2007, 07:59 PM
  2. laptop power on off
    By onlineamiga in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-20-2005, 11:33 PM
  3. Any downsides to a laptop car adapter as a power source?
    By BlackAWD in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-20-2005, 06:59 PM
  4. Power laptop from headunit?
    By LordSnow in forum Newbie
    Last Post: 04-07-2005, 10:25 PM
  5. Power button extention on a laptop
    By oafdawg in forum General Hardware Discussion
    Last Post: 05-18-2004, 09:26 PM
