Page 16 of 37 FirstFirst ... 67891011121314151617181920212223242526 ... LastLast
Results 151 to 160 of 368
Thread: Laptop Auto Power-On / Turn-On Module
  1. #151
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    button is alot easier on many laptops (trust me ive repaired laptops for 2 years on job)
    On mine there is no ribbon cable or similar. the button board presses onto a small connector on the mainboard then its screwed down. so no cables to play with. And you're not going to be able to solder onto the small connector on the mainboard. It's a press fit and very small, plus the button board sits on top of it blocking all access.
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
  2. #152
    Constant Bitrate RyanB95's Avatar
    Dec 2006
    Wallkill, NY
    So what am I supposed to do?
    1995 AWD Tsi Talon
    Intel D945GCLF
    M2-ATX
    2GB Corsair
    30GB OCZ SSD
    BU-353
    Lilliput EBY-701
    Logitech DiNovo Mini
    LSX VOID 3.3
  3. #153
    Constant Bitrate rsxtypes's Avatar
    Nov 2006
    Dallas, Tx
    Are you saying it would be easier to try to get at the wires behind this membrane (that is probably adhered to that plate) ...
    than to solder on these clearly visible posts?
  4. #154
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    I think RSX is right here, it'd probably be easier to solder to the leads from the socket for your ribbon cable. You'd just need to be very careful and very precise. Before you start, do like you did for the membrane switch/lid switch check the leads with a multimeter on the continuity setting. Have your ribbon cable in the socket, press your button and test the leads till you get the desired BEEP (make sure your laptop is unplugged and the battery is out)
  5. #155
    Nov 2006
    Dallas, Tx
    Quote Originally Posted by W3bMa5t3r View Post
    Thanks for cutting that picture down for me. I just wanted to add you are not looking at the pins inside the connector. You want to look at the soldering pads at the base of the connector. There are 5 of them clearly visible on this side of the connector. I am not sure what is on the other side of that connector there may be more.
  6. #156
    Dec 2006
    Wallkill, NY
    Just in case it helps at all - Here's a picture of the back side of that connector:
    And here's where I mounted my jack. I didn't need my speakers anymore since I would be using the laptop in my car all the time so I removed them and that gave me a perfect spot to mount the jack:
    1995 AWD Tsi Talon
    Intel D945GCLF
    M2-ATX
    2GB Corsair
    30GB OCZ SSD
    BU-353
    Lilliput EBY-701
    LSX VOID 3.3
  7. #157
    Nov 2006
    Dallas, Tx
    I go back to my question from earlier: Do you own a multimeter? It is really hard to make guesses from a picture on where wires go. Guesses, that may or may not fry your system.
  8. #158
    Dec 2006
    Wallkill, NY
    I don't own a multimeter, but I have access to one. I'll grab it today and try to figure it out. All I'm doing is figuring out which two soldering points beep when the button is pressed, correct? Polarity isn't an issue?
    1995 AWD Tsi Talon
    Intel D945GCLF
    M2-ATX
    2GB Corsair
    30GB OCZ SSD
    BU-353
    Lilliput EBY-701
    LSX VOID 3.3
  9. #159
    Nov 2006
    Dallas, Tx
    Quote Originally Posted by RyanB95 View Post
    That is correct. You want to set the multimeter to Ohms. You aren't going to be interested in voltage or amperage. Polarity isn't an issue.
  10. #160
    Feb 2007
    Laptop Power supply/ and auto power up /shut down
    Not really, but you can build these yourself and thus cheaper that way. Or having someone build one for you, saves you the time and effort and they are still cheaper than the other 'commercial' products. The commercial products do plug into serial ports, etc... usually. These we're building are just simple power on/off designs. The commercial ones also throw in all kinds of frills, bells and whistles, though you pay for that as well. All up to you... Just offering this as a service/as info for the community. ;-)
    Hello, I am new to this forum guys,
    I therefore introduce myself and let you know it's been a very educational site to read. Thanks for all your help.
    I would hope someone could reply to this request of an explanation.
    Basically i am about to biuld my first carputer. I was going to build it using an EPIA but then i found a new laptop with a faulty screen from factory for less that EUR 100 (USD 120 - GBP 65 ).
    So i bought this DELL XPS M1210 and going to use this as my carputer.
    I am going o use a touchscreen monitor as well and I am confused on what to do in respect of the followings:
    How to connect the laptop and the screen to a DC - DC supply
    so that
    the laptop and the screen to turn on together simultaneously as the ignition starts
    and turn off when i turn the engine off
    (with the possibility of deactivating this function).
    I hope someone is so king to help me, so far i have read all your threads but i am very confused. I have seen the switch shown in the pictures above but i don't understand how the laptop and the screen are powered.
    I am a total newbie, but i learn fast.. so please help :-)
    I promise i will post loasd of pictures as i build and finish my carputer..
  1. Laptop Power On I've Searched Help Please
    By TimStark in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-28-2007, 07:59 PM
  2. laptop power on off
    By onlineamiga in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-20-2005, 11:33 PM
  3. Any downsides to a laptop car adapter as a power source?
    By BlackAWD in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-20-2005, 06:59 PM
  4. Power laptop from headunit?
    By LordSnow in forum Newbie
    Last Post: 04-07-2005, 10:25 PM
  5. Power button extention on a laptop
    By oafdawg in forum General Hardware Discussion
    Last Post: 05-18-2004, 09:26 PM
