Page 19 of 37 FirstFirst ... 91011121314151617181920212223242526272829 ... LastLast
Results 181 to 190 of 368
Thread: Laptop Auto Power-On / Turn-On Module
  1. #181
    Low Bitrate slinkytoy's Avatar
    Mar 2007
    Colorado
    dell inspiron 8200 notbook
    I have a dell inspiron 8200 notbook that i have that I'm going to install into my truck. The power turn is on a board that plugs into the motherboard will this turn on unit work with this kind of connection. Any help would be great.
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    Quote Originally Posted by slinkytoy View Post
    If there is a momentary push button on the board it will work. You would solder in the leads as you would on a laptop. You'll have to test it though to be certain. Use the same test method as previously mentioned for the laptop power buttons.
    Cheers, The W3bMa5t3r
  3. #183
    Apr 2007
    will this module work for inspiron 600m?
  4. #184
    Apr 2006
    Quote Originally Posted by bangumandoo View Post
    Too funny. I was just updating the first post. Check it out.
  5. #185
    Constant Bitrate jwlionking's Avatar
    Apr 2005
    Saxton, PA - Central/Western PA
    Great Module. Mine is working great! What do you suggest for the reverse effect? I find myself using the momentary switch you supplied to put it into sleep. Is there a way to build the box to do the opposite too?
    DigitalFX4.0 Skin by JohnWPB
    Road Runner RR's Myspace
    My Ride - Car Domain Page -JWLionKing's MySpace Page
    Project 98% Complete -FREE DOMAIN & WEBSPACE / FILE HOST FOR DEVELOPERS - PM ME
  6. #186
    Apr 2006
    Quote Originally Posted by jwlionking View Post
    If you're using it with a laptop, you should be able to just set the ACPI / Power Settings to shut down / hibernate / standby the system once you turn the car off and whatever is supplying power to your laptop is turned off. Say after 45seconds after power loss it goes into standby/hibernate mode.
    As far as building the reverse mode... I'm sure there is, I just haven't devoted the time to it as I have too many irons in the fire as it is lol. Maybe one of these days
  7. #187
    Newbie silicoon's Avatar
    Mar 2007
    sydney
    hi man
    I hooked up your module and the usb function doesnt work - it still shuts down when i turn on the car
    just wondering how you wired it because i cut the USB plug and wired it to another extension that goes to my hub - so i dont loose a usb port - im guessing red is + and black is - :P let me know...
    im going to have another look at it, but its not workin atm!
    anyway i can check if its taking in the power properly etc?
  8. #188
    Apr 2006
    Quote Originally Posted by silicoon
    hi man
    I'm guessing you mean you already have the pc ON then, when you turn on the car? How is your HUB powered in relation to the module and pc?
    I've attached a pic showing the usb connection on the board. Basically just positive and negative from the usb cable should be read here. +5vdc on the one side, Ground/Negative on the other. Also, when you plug the usb cable in to a port that is powered on, you should hear the smaller, 5vdc relay 'click'.
  9. #189
    Mar 2007
    sydney
    no worries ill check it soon! cheers bruz
  10. #190
    Mar 2007
    sydney
    hey i checked and the relay does tick over when i add power, but it still resets on startup etc...
  1. Laptop Power On I've Searched Help Please
    By TimStark in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-28-2007, 07:59 PM
  2. laptop power on off
    By onlineamiga in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-20-2005, 11:33 PM
  3. Any downsides to a laptop car adapter as a power source?
    By BlackAWD in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-20-2005, 06:59 PM
  4. Power laptop from headunit?
    By LordSnow in forum Newbie
    Last Post: 04-07-2005, 10:25 PM
  5. Power button extention on a laptop
    By oafdawg in forum General Hardware Discussion
    Last Post: 05-18-2004, 09:26 PM
