Page 2 of 37 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 368
Thread: Laptop Auto Power-On / Turn-On Module
  1. #11
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    Sorry...last question...did you also get the plastic box from radio shack, did you make it, or just had it lying around?
    Brown 2010
  2. #12
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    Quote Originally Posted by Sidewalksalvage
    I'm cool with questions so don't worry about it, but yeah I bought the box at radio shack, but any small box would work.
  3. #13
    Mar 2006
    NJ/RI
    Okay scratch that one again...i notice in an earlier picture the "project enclosuers" packaging from radio shack... thanks again
    -Luke
    Brown 2010
  4. #14
    Apr 2006
    -Luke
    LOL yeah I acutally just noticed that myself. oh well. :-\ It's all good. Peace.
  5. #15
    Apr 2006
    Updated Pics / Schematics and Other Info as requested. :-)
  6. #16
    Apr 2006
    Utah
    That is really cool...can I ask you a electrical question? (I sure wish I was smarter that way!!!)
    Can I just solder and wire a turn on switch to my laptop docking station? I'm going to have a constant power connection through a DC - AC inverter.
    I can turn off the computer but need something to turn it on because I mounted it in the trunk. Any help you can give me would be great!!
  7. #17
    Mar 2006
    NJ/RI
    Is there a switch on the docking station? I dont know how easy that will be. You may want to consider something like creating a plug on the laptop like suggested above, then adding a connection on the dock.
    Basically that way you can mount the dock in the car and hook it up all nice, then when you put the laptop in, you add the power switch plug as well.
    Okay that was kind of confusing explanation.....but i think you can get my drift....
    Brown 2010
  8. #18
    Apr 2006
    Utah
    The docking station does have a power switch. My thoughts with the docking station is that I would rather ruin my $10-15 docking station, than my $600 laptop. Does the above device work when the laptop/docking station is under constant power (DC - AC inverter)? Can it still sense the "Turning on" of the car the the switched power lead?
  9. #19
    Apr 2006
    Quote Originally Posted by hunter5482
    The module will work with anything that uses a momentary switch to turn the device on. It replicates a momentary switch press for about 1/2 second. You simply wire in the +12vdc (red) and GND(black) to a line that receives power when the car is on and it will replicate the switch press. The green wires are soldered to the momentary switch, either on the laptop, docking station, LCD monitor, whatever...
    For the safety function (so it doesn't send a second press for whatever reason), you need the usb part of the module plugged in as well. This does require you to use hibernation and not standby.
    Hope this helps... later
  10. #20
    Apr 2006
    Since I've been asked quite a bit, yes, this can be used to turn on a LCD monitor if it uses a momentary switch. This module replicates a momentary switch, so it can be used for anything that uses a momentary switch to turn the device on. LCD monitors, laptops, desktops, docking stations, external hard drives, etc. Enjoy
  1. Laptop Power On I've Searched Help Please
    By TimStark in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-28-2007, 07:59 PM
  2. laptop power on off
    By onlineamiga in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-20-2005, 11:33 PM
  3. Any downsides to a laptop car adapter as a power source?
    By BlackAWD in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-20-2005, 06:59 PM
  4. Power laptop from headunit?
    By LordSnow in forum Newbie
    Last Post: 04-07-2005, 10:25 PM
  5. Power button extention on a laptop
    By oafdawg in forum General Hardware Discussion
    Last Post: 05-18-2004, 09:26 PM
