Page 26 of 38 FirstFirst ... 161718192021222324252627282930313233343536 ... LastLast
Results 251 to 260 of 378
Thread: Laptop Auto Power-On / Turn-On Module
  1. #251
    Jun 2007
    ok i got it.
    I suck at schematics but if you want one of these things let me know, email me.
    Since I have to buy so many things at a time I will sell some if anyone wants one.
    No big deal
  2. #252
    Oct 2007
    Quote Originally Posted by nserpa9248 View Post
    thats what i meant, grabbing +12v from the laptops internal power, (what powers the processor, ram, HD, etc) im not too familiar with laptops, but there must be some connector or pin or something that we can get power from. ill ask some of the techs at my work about this..brb
    why dont you just grab power from the "powered on" LED. This LED is not affected by anything "software". Its ON if the laptop is ON and its OFF if the laptop is OFF. It will stay on even trough restarts and OS crashes. I have worked with a couple different laptops in the last few years and all of them have the power LED very close to the power button if not in the same place.
    In my set up I wired the power switch and the power LED. That way I have a remote button to turn it on/off plus the LED that gives me the status. I was thinking of getting the auto-power on module but its doesn't have a LED pass trough I want for status display. It shouldnt be difficult to wire the LED instead of using the laptops USB to tell if its ON/OFF and add a LED to the remote power switch of the module. One of those lighted switches would be awesome.
  3. #253
    Low Bitrate Vinster03XR's Avatar
    Jan 2007
    Near Toronto but not in it
    ^ I like your idea of using a CAT5 plug and cable.... I used a molex connector and its clunky to plug/unplug... Good Idea
    Vin
    Carputer works... but will never be complete....
  4. #254
    Oct 2007
    Quote Originally Posted by Vinster03XR View Post
    Vin
    the only thing to keep in mind when using CAT5 is that the wire is a little too stiff. I tried soldering the CAT5 wire directly to the LED but it would come out once the wire started to move and flex. I used a thin flexible wire and soldered it to the ends of the surface LED and then joined it to the CAT5 wire. The thin wire flexes really easy without putting stress on the solder joint on the LED.
    Soldering the CAT5 to the switch contacts was no issue though.
    Im sending the power button and the power LED trough the CAT5. It still has 2 more wire pairs available for future use, maybe I could send the microphone and the HDD LED. The color coded wires make it easier too.
  5. #255
    Jan 2007
    If you would have use stranded CAT5, you would not have had the problem with the wire being too stiff... Be-heading a pre-made 10ft cable would have worked well too..
    Props to you.
    Vin
  6. #256
    Oct 2007
    Props to you.
    Vin
    gotta get me some of that stranded CAT5. I think we only use solid wires even for patch cables. If I find a factory made patch cable Im gonna cut it up and check it. Maybe after the 10 or 11th be-heading I'll find a stranded one :-)
  7. #257
    Jan 2007
    Here normally the 3ft to 25ft pre-made cables are stranded... and the supplier that I get my networking hardware from sell both Solid and Stranded RJ45 Connectors... So I'd think it would be common....
    Where do you live?
    Vin
  8. #258
    Feb 2008
    Unhappy
    I get this error when i try to Checkout in your store.
    I live in Mississauga, Ontario Canada.
    I want to buy your Laptop Auto Power-On Module, What can i do? Can I send the payment to your email through PayPal?
  9. #259
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Quote Originally Posted by rafynet View Post
    Seems there was a misconfiguration with the international shipping. Should be all good now so give it another go. Thanks
  10. #260
    Feb 2008
    New York
    Additional Option
    I think I found another work around for the some folks (depends on the laptop). I would first start by looking into getting (if you don't have it already) the docking station for your laptop. I am using an HP NC2400 and it's dock. Instead of fiddling around and soldering my Laptop motherboard I decided to see if I could hack the dock instead. Mose docks have there own power switch which function the same way the onboaed switch does (while the machine is in the dock of course) Obviously this is a lot cheaper to replace if things go bad. So upon opening up my dock I found the the power switch and LED were on it's own standalone circuit board and wired to another control board within the dock. I clipped the wire at the 1/2 way point and plan on extending this wire by splicing in some of my own. There are 4 wires in all to control things like one touch standby or a hold down for complete power off...etc. I'll keep you posted on my progress if anyone is interested. Should take me a few more days to work on and test things out. Now I do understand that not all docks have the convenience of having the power button separate from the rest of the internal components, but that is where using an item like the one offered in this thread comes in...only this time instead of possibly ruining your $1500.00 laptop you are only hurtung a $50.00 - $100.00 dock. By the way using a dock has other benefits as well...Usually they have more USB Ports, and allow you to easily remove your PC from your car for safety / maintenence etc. without unplugging everything.
  1. Laptop Power On I've Searched Help Please
    By TimStark in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-28-2007, 06:59 PM
  2. laptop power on off
    By onlineamiga in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-20-2005, 10:33 PM
  3. Any downsides to a laptop car adapter as a power source?
    By BlackAWD in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-20-2005, 05:59 PM
  4. Power laptop from headunit?
    By LordSnow in forum Newbie
    Last Post: 04-07-2005, 09:25 PM
  5. Power button extention on a laptop
    By oafdawg in forum General Hardware Discussion
    Last Post: 05-18-2004, 08:26 PM
