Page 30 of 38 FirstFirst ... 20212223242526272829303132333435363738 LastLast
Results 291 to 300 of 377
Thread: Laptop Auto Power-On / Turn-On Module
  1. #291
    Constant Bitrate peijffertje's Avatar
    Nov 2005
    Netherlands
    Hi W3bmast3r, I cant check out my item on your webshop, which probably has got something to do with the fact that it has to be send to the Netherlands.
    I bought 1 from you before so I know you ship outside the US. Can you look into this or PM me on how to make my payment outside your webshop?
  2. #292
    Sep 2008
    I'm buying one of these. I was going to use a RF momentary robot switch, but the auto-turn-on feature is much too convenient. Can anyone post pics on the remote power on/off switch installation? I was thinking of mounting it in one of the switch blanks in my dash board, but I guess I would need to buy a factory dash momentary switch for my 06 Odyssey. Otherwise, I guess I could drill a little hole in the middle of the existing blank and install the supplied button. I would like it to look as OEM as possible.
  3. #293
    Low Bitrate docbreezy's Avatar
    Feb 2008
    Maryland
    So Supposing one wanted power the momentary switch using the 5V relay through a USB port, could i just put that relay inplace of the 12 volt one? Here is what im thinking, I have made one of these to power up the laptop and it works flawlessly, Thank you webmaster. But i want to make one for my monitor, but i don't want all the booting junk to show, so i want it powered when the USB is powered, usually when windows is logged on and hopefuuly by then, RR will have been initialized. I am not technical, and haven't used ohms law since highschool so any help s appreciated.
  4. #294
    Feb 2008
    Maryland
    Someone, Anyone?
    506 Skin
    506 Flash!
    NEVER BLEND IN!!!
  5. #295
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    they recieve 5v upon power applied to computer so it would'nt work.
    similar problem:
    I keep my PC in standby so the usb protect method is no good.. i was thinking on tapping a VGA pin 9 (suppose to be 5v on newer d-sub) so when computer comes out of standby it will trigger N.C. relay to stop from going into standy once on..anyone done this or other solutions besides the usb protect option?
    Did it.. Done it... now I got to keep the neighbors kids away!!
  6. #296
    May 2008
    San Jose, CA USA
    My laptop is a Toshiba Satelite A105. Can you build the gadget for this laptop? Also what is the pricing on it?
  7. #297
    Aug 2008
    the units are completly universal. His price is cheap cause I built one and it cost me almost the same as he builds them, he ain't jokinf when he says he dont make profit.
  8. #298
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Just wanted to let everyone know I'm back and I am making these modules again (along with the usb power modules). The site should be good. =)
  9. #299
    Dec 2008
    Could someone post up a video of the device in action in different scenarios, such as with it turning on the computer, turning off the computer, key on then off quickly, key off then key on quickly. thanks.
  10. #300
    Constant Bitrate Startingline13's Avatar
    Nov 2007
    Long Island, NY
    I'm interested in picking one of these up for my laptop in my Jeep liberty. I have a question about the ACC/RUN wire that I need to connect the black/red wire to.
    I have a 2002 Jeep liberty, so I just want to verify that the black/white ACC switch as seen on this wiring diagram:
    http://www.the12volt.com/installbay/...s.asp~TID~1573
    Furthermore, if I purchase a Carnetix CNX-P2140, will it be able power the laptop on/off automatically, or will I still need this device?
  1. Laptop Power On I've Searched Help Please
    By TimStark in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-28-2007, 06:59 PM
  2. laptop power on off
    By onlineamiga in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-20-2005, 10:33 PM
  3. Any downsides to a laptop car adapter as a power source?
    By BlackAWD in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-20-2005, 05:59 PM
  4. Power laptop from headunit?
    By LordSnow in forum Newbie
    Last Post: 04-07-2005, 09:25 PM
  5. Power button extention on a laptop
    By oafdawg in forum General Hardware Discussion
    Last Post: 05-18-2004, 08:26 PM
