Page 38 of 38 FirstFirst ... 2829303132333435363738
Results 371 to 377 of 377
Thread: Laptop Auto Power-On / Turn-On Module
  1. #371
    Nov 2011
    Thanks for the reply.
    To clarify, I am not running a headunit. The only devices on, what used to be, the radio accessory line are a minitouch 700, remote wire for an amp, and the auto-on circuit.
    On a more relevant note (to this thread), how have others mounted this in the past? Small project box?
  2. #372
    Low Bitrate Vinster03XR's Avatar
    Jan 2007
    Near Toronto but not in it
    then I think you have something wrong. all those devices should only take 2-3 amps max.. do you have a clamp meter that can read DC? or run a meter in-line with a 10amp fuse to not pop your meter..
    Vin
    Carputer works... but will never be complete....
  3. #373
    Nov 2011
    Do not have a clamp meter. Bought a meter that could measure 10 amp, but the display is bad. Hopefully I can exchange it tonight and try to determine what I did wrong.
  4. #374
    Low Bitrate FockMasterDan's Avatar
    May 2008
    Westerville, Ohio
    Does anyone out there have the schematics for this module? He doens't have it hosted on his site anymore and I'm having trouble with my unit. I've continuity tested the input to the computer (that's wired to the power button) and it's constantly connected while the module is disconnected.
    Computer is in the car, but in a very "raw" install right now.
    Worklog - here
  5. #375
    Oct 2004
    NY
    Quote Originally Posted by Cerberus View Post
    C
    it's there, a few posts above yours
  6. #376
    May 2008
    Westerville, Ohio
    Quote Originally Posted by turbocad6 View Post
    Thanks a bunch. I had searched for it but I was bombarded with results leading me to broken links.
    Worklog - here
  7. #377
    May 2008
    Westerville, Ohio
    Just a quick follow up, it was a really simple issue. Vibrations had shifted the resistor so it's lead was touching another component's lead. Bent it back straight and put shrink over it for good measure and I'm in business.
    Worklog - here
  1. Laptop Power On I've Searched Help Please
    By TimStark in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-28-2007, 06:59 PM
  2. laptop power on off
    By onlineamiga in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-20-2005, 10:33 PM
  3. Any downsides to a laptop car adapter as a power source?
    By BlackAWD in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-20-2005, 05:59 PM
  4. Power laptop from headunit?
    By LordSnow in forum Newbie
    Last Post: 04-07-2005, 09:25 PM
  5. Power button extention on a laptop
    By oafdawg in forum General Hardware Discussion
    Last Post: 05-18-2004, 08:26 PM
