HEY CDR the joypad can it control the mouse movement. I want to be able to control the Iguidance Pan movement when it search mode. is it possible haven't even tested it yet.
Printable View
Doesnt work for Xbox Controllers using usb...
Ok, can someone tell me why this isnt working for me? I can see the name of the controller in the list but it still says it unplugged. AND the controller works fine through windows.
Luv it mate.
Lokked at it thought now thats useful....eg going to do persactly what u ave done on ur steerin wheel. Downloaded it, opened it up, whipped out my usb jostick, and bang it worked instantly. So now ill go and buy a usb gamepad, to rip apart and intergrate it into the steering wheel. Cheers CdRsKuLL, thnx for the VERY EASY 2 USE....and USEFUL little progy u made up. :p
yeah i guess theres no support for those who are having problems with this program.
CDR,
Works great with GGE910 Wireless PC Control Pad.
Have you ever thought about using the controller to respond to each sub menu item? For instance, you're on the main menu. The buttons could be used to direct you to sub-menus like GPS or audio. Once in the GPS menu, the controller will focus on just GPS functions. Common controls like volume and exit back to main menu could be used on all menus/sub-menus.
@ iselfdevi,
I'm not sure what your problem could be. I tried my controller and it showed up instantly. I did notice that I have to switch to analog mode to get the controller to actually work the first time. After that, it works in both modes. I wish I knew how to help you out a little more.
It's been less than 3 days since you posted your problem.
It's a free program written by one guy, it is not a commercial app written by a company with a large development team and support team(who from my experience can sometimes take wekks to get back to you, if at all). You can't expect him to be on the forum 24/7 just for you, he has a normal life outside of here just as we all do.
And with that attitude, if it had been one of my apps I would now be of a mind to ignore your problems.
Just stumbled across this by accident. I am having the same problem with this that i have been having with version 1.1
Generic USB gamepad
Works in control panel
Works in games
Start app
select "USB GAME CONTROLLER" from dropdown list
press save settings
says "updated settings.ini"
press ok
reports "device unplugged" and "USB GAME CONTROLLER" disappears form the dropdown box
winXP SP1
cant think of any other useful info!
I have the same prob as iselfdevi, could someone explain what i'm doing wrong please.
