Jasin,
That's only IF we can find them somewhere. No luck yet, I'm starting to look for other options.
In addition to that problem, the USB jack itself will be too tall to fit into the upper right of the bezel. I'm trying to think of a way around this. I may have no choice other than using a Mini-USB port, in which case you'd have to use an adapter cable because most devices are the standard sized USB connector.
- Brett
FMode,
Do you have a USB audio controller that you are familiar with? I'm looking for a solution to integrate into this product.
I'd like a USB system with 3-5 Stereo line INPUT pairs, that all will show up in the
Windows volume mixer. These inputs will be for the external AV in on the back of the unit, as well as for the internal FM
radio module. I'm having difficulties finding a good solution. I'm thinking a USB to AC97 converter, and then one of Via's AC97 audio chips would work. But I cannot find a USB->AC97 chip. Then there is USB to I2S, and some I2S ADC's. But the USB->I2S chip I found requires some special firmware and programming (TUSB3200).
Ideas?
- Brett
