If I could get a unit with the following options, I would pounce on an order of over 100 units almost immediately.
REQUIRED:
1.
Software accessible buttons with BACKLIGHT (at least 6 please).
I'm thinking somewhere between 6 and 10 buttons.
Something such as this:
http://www.rockwellcollins.com/ecat/gs/graphics/pfd.jpg (notice how the buttons are positioned so the on-screen menus can line up with them). Here’s another decent looking design:
http://img.diytrade.com/cdimg/405567...1156943447.jpg
2. >= 400 nits brightness (or transflective option)*
The LCD is 380cd/m2, without the touchscreen layer. We will also offer a transflective upgrade option for these, however, this upgrade will be expensive ($350ish**).
3. Double DIN compatibility - no need for dash modification.
Nice to have:
1. Black finish.
2.
Windows CE with available BSP as done by VIA.
3. SD or CF slot to allow easy upgrading/maintenance.
4. Non-motorized.
5. Built-in USB port.
Will you be running Windows CE? Do you have a processor in mind? Have you considered creating your own LCD backlight using white LEDs? I'd imagine the
power consumption would be reduced somewhat.
It will not run CE. The models with a motherboard inside are just that. You can run whatever you'd like on it. The LEDs would be a lot of work. I think the CCFL that comes with the LCD will work fine for the time being.
As background info, I would be using this for a custom software application in emergency vehicles (ambulances mainly – 95% of which are Ford E or F
series). For this reason, brightness and durability have the most weight of all my needs. Being able to navigate my application's menu using the buttons will prevent the LCD from being poked at 24/7, so it's important to have this feature.
I think the buttons, as well as a rotary encoder knob, will help a lot in this situation.
Also, if it's possible, I'd like to have the ability to run my application on the device itself, as opposed to using an external PC (save a bit on total costs).
We will offer a version of the product with an included PC system that you can use to run your own applications.
I must say I'm quite excited to finally come across a device that meets my needs. Based on the trends and
requirements of my field, this device will be in demand for not only the car enthusiasts, but also for industrial/commercial applications. I look forward to seeing what you have to offer.
