Page 4 of 58 FirstFirst 123456789101112131454 ... LastLast
Results 31 to 40 of 574
Thread: Production Double-Din VGA Touchscreen in the making!
  1. #31
    Oct 2004
    Bay Area, CA
    No it wasn't already designed. The biggest thing was sourcing the LCD screen since the whole design replies on that specific model.
    Think about it. Prototype PCB's take 2 weeks or so, and a production run of PCBs and enclosure takes roughly 4 weeks (depending). We have between 10 and 18 weeks to stay on target (April/May). We can do it!
    Like I said, we're both working very hard on piecing this whole thing together and making it work. We've needed a product like this on the market for a long time now!
    Kinda early to give a final price, but I estimate Version 1 & 2 ~ $725.00, and Version 3 @ ~ 1,399.00. Please don't quote me on this. They may be even cheaper than the DL065A's, or a bit higher than this. Again it's still too early to tell.
    - Brett
    PS: I forgot to mention: I believe the firmware on the controller will be USB upgradeable, so new features can be added later.
  2. #32
    Mar 2006
    Colorado, but Canadian!
    If you want to give any away for beta testers, let me know!
    I'll definately be keeping an eye on this.
    1.9in x 2.9in -- 47mm x 73mm
  3. #33
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Quote Originally Posted by Mrbmw99 View Post
    However, I have since found different sources to get the 6.5" LCD's from. This means we will be using the SHARP 6.5" WVGA 800x480 LCD's in our design.
    I think you made a great choice. A few years ago I would have said go for the 7", most people woudnt mind because back then the people doing this in car computer stuff were serious about it and didnt mind fabricating. Its not a hobby now. Today you need to make everything so simple your grandma could operate it, and anyone that can read instructions can install it. You arent dealing with just hobbyists anymore.
    2005 Ford Focus ST
  4. #34
    Nov 2006
    I did not see anything mentioning a dvd drive, I take it, it is assumed but I just want to make sure.
  5. #35
    Apr 2006
    Also, what about adding some RCA preamp audio outs (front, rear, sub)? Maybe even do away with the internal amp... That is one of hte reasons I didn't get the digitalww one.
  6. #36
    Oct 2004
    Bay Area, CA
    Quote Originally Posted by Jasin View Post
    Yes, there will be a CD/DVD drive inside the unit.
    Quote Originally Posted by 06BlueZ View Post
    Post #26, this thread:
    (1) Set of 4 (LF, RF, LR, RR) 3v RMS Pre-Outs for external Amplifier
    - Brett
  7. #37
    Jan 2006
    I know I would like small things like:
    having the ability to set primary input (on power on) through a jumper or the like.
    The ability to have a customisable 'spash screen' with a delay before switching to primary input. (this would likley be a function of the LCD controller itself, but with my experience with LCD's it can be changed)
  8. #38
    Mar 2005
    Wiesbaden/Germany
    huge hug for BMW99
    I believe these "TFT-manufacturers in the east" will never get it done right... it must be done by the community...
    so here is the way to go:
    Do you need help with the Firmware (the dead reckoning algorithm is somewhat tricky I think) ? Go Open Source and we (the car pc community) will kick *** (and implement dead reckoning later).
    ...as Amplifier you can take a TDA 7560 (?) - for Radio you can buy something from XTronic ?
    .... and lets collect for Bill Gates he will not be the richest man on the world if this Indash Unit is done !
  9. #39
    Mar 2005
    Wiesbaden/Germany
    Tenative Info:
    Version 1: (Basic Video-Only HU)
    (1) External VGA Input
    (3) External Composite Video Inputs
    (1) B-Style USB Connector (for connecting to the external PC)
    (2-4) A-Style USB Connectors (for connecting external gear like GPS to the HU)
    Version 2: (Basic HU with Internal Audio Support)
    (3) External Audio Line-Inputs (Paired with the Video Inputs)
    (1) 4x45w Amplifier (LF, RF, LR, RR) Speaker Outputs
    (1) Digital Audio Input RCA (SPDIF?)
    (1) Digital Audio Output RCA (SPDIF?)
    Version 3: (Full Blown Internal CarPC System, with external A/V inputs)
    (2-3) External Composite Video Inputs
    (2-3) External Audio Line-Inputs (Paired with the Video Inputs)
    (4-6) A-Style USB Connectors (for connecting external gear like GPS to the HU)
    (1) Internal Nano-ITX PC System
    (1) RCA Video Output (connects to Nano-ITX Mobo)
    Version 2: Please add a Radio with RDS (!!!!) and a simple USB Audio Controller for 5 Euros (saves audio lines running through the car from the trunk-pc)
    (I think a Diversity TV Tuner WITH USB video grabber (!!!) is too expensive )
    This USB Audio controller is for the non-car-pc people (the masses) without amplifier in the trunk.
    Does a removable GPS board make any sense ? Who of us is not doing navigation with its car pc ? So we all need GPS...
    ...and a GPS without Deadreckoning doesn't make its really more expensive but makes your unit VERY professional so that it can easily compete with Alpines and Blaupunkts and stuff.
    For Version 3 you got my full respect if you got this to fly ! I think this will be VERY difficult to fit a Nano-ITX inside (if I look into my CID650)
    I am waiting 7 years now for such a product...
  10. #40
    Oct 2004
    Bay Area, CA
    Quote Originally Posted by FMode View Post
    Thanks for the diagram - it's actually pretty close to what will be done. I haven't looking into the TDA 7560 yet, but I will. I think we will be using the Microtune AM/FM/RDS modules (IF they ever return my calls!).
    Boy - that'd be nice!
    I am looking into using USB audio chips. This would be my preferred way of doing this because it would allow the frontend to "fade" or switch between audio sources nice and cleanly.
    The GPS will be a module that we can install. It's not our design. So, it's easy for someone to say yes they want it or no they do not. Either way, the mainboard will have the circuitry to interface to it regardless of whether or not the module is actually install (meaning it can even be added later). I don't know much about dead reckoning, maybe you can send me some good documentation?
    It will be tight in there, but I'm sure it will work ok. In the CID650/DL065A, it wasn't really meant for an internal board. The DVD drive is mounted low, there are a lot of tall components on the mainboard, right in the center, etc etc... Plus, a Nano-ITX is only 4.7"x4.7" wide. Then I have to do the HDD, PS, Heat-Dissipation, etc, but it should all work. Great thing is - we will have an answer from the CAD software before we even start building anything!
    So can we consider you a customer now?
    - Brett
  1. Double din VGA monitor
    By afarre in forum LCD/Display
    Last Post: 11-01-2010, 12:56 PM
  2. Replies: 18
    Last Post: 08-28-2009, 06:16 PM
  3. 1/2 DIN size touchscreen
    By TheTreeHouse in forum LCD/Display
    Last Post: 11-01-2007, 09:41 AM
  4. Double Din VGA Touch Screen?
    By mswanson00 in forum LCD/Display
    Last Post: 05-30-2005, 02:21 AM
  5. Double Din to Single Din
    By loganm in forum General Hardware Discussion
    Last Post: 03-20-2005, 10:58 PM
