I like the idea of keeping the usb on the front. Maybe offering a little rubber molded cap to cover it like the plug covers on a digital camera would be good. That way it's accessible, but covered when not in use.
I saw the round spot at the top and I'm wondering if that's for a knob? Are you looking at a basic rotary encoder or a multi function unit? I've seen the multi function units at Mouser and my favorite is the dual shaft unit:
http://www3.alps.co.jp/WebObjects/ca...KJXM/RKJXM.PDF
There's also the single shaft unit:
http://www3.alps.co.jp/WebObjects/ca...KJXT/RKJXT.PDF
The reason why the dual shaft unit is more favorable (to me anyway) is that you have the rotary encoder connected to the outside section (volume, control, etc). Then there's a hole in the center allowing access to the directional control stick (or nub of some sort). I'll draw something up quick when I get a chance today and I'll post it to show what I'm talking about. That dual shaft unit is 8 way with center click and has detents for the rotary encoder. If something like that could be included in the controller with the other buttons that would be great. That would take the button count up to 14 and I'm sure that whatever controller you are using can handle that.
Afterwards, you'd just need some good programmer to write the code to allow the button presses on the unit to map to macros, key strokes, or
windows events (volume, play, pause, etc).
Great work so far. If you guys need any other help with the 3D design I'm using SolidWorks and have access to a seat whenever I need it.
