Page 18 of 36 FirstFirst ... 8910111213141516171819202122232425262728 ... LastLast
Results 171 to 180 of 354
Thread: W3bTracker - GPS Tracking & Secure Location Marking (also offering Mologogo tracking)
  1. #171
    Jun 2002
    Virginia
    Quote Originally Posted by MobiTekLink View Post
    Well, I assigned COM5 to IG, I assigned COM6 to W3btrack, I enabled the service but I either get the error or sporadically iG won't work.
    It's funny because W3btrack status globe is green, and the bad thing is that Xport is not too status friendly.
    It sounds to me like you're having a port conflict. What version of Xport are you using? If it doesn't have a scan button on it it's not the newest version. I have attached the newest version. Try using this one and hit scan before you set the ports so it refreshes the available ports. Maybe you ought to use a higher number for Webtracker (I'm using 12). As I said earlier, Xport has been rock solid for me once I've set the ports correctly so there must be something else going on.
    Attached Files Attached Files
  2. #172
    Maximum Bitrate MobiTekLink's Avatar
    Jun 2005
    Queens, NYC
    Ok, Ill try that one; Im just using the one that w3b includes in his program.
    I didnt' figure to change the ports...
    THANKS!
    08 Lincoln Navigator www.mobiteklink.com
  3. #173
    Jun 2005
    Queens, NYC
    By the way, I'm using serial port COM2, Do I need to setup iGuidance to THAT COM port or use two different ports for iGuidance and Webtrack ??
    Like I had it, incoming COM2 , outgoing COM5 and COM6 ... Is that correct?
  4. #174
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    You 'should' be good like that. My setup has incoming GPS at COM8 and xport splits that to COM13, 14, 15, 16, 17
    iGuidance uses 14, W3bTrack 16.. a few other things running off the others...
    Com2... isn't that a system com port though? usually com1 is your 'real' serial port.. com2 another system com port... (though I've been going a while without sleep.. so I could be off.... )
  5. #175
    Jun 2002
    Virginia
    Open iGuidance outside of RR. Go to tools/GPS Options/autodetect. After a minute or so it will tell you what com port iGuidance is using. That's the port your GPS receiver is using and should be the port set as input in Xport. Exit iG. Now in Xport set the input port to the port determined above. In Xport hit scan. Then pick three available com ports in the output section. Make a note of the three outputs you have chosen. The first output port will be for iG, the second will be for RR and the last will be for Webtracker. Hit enable in Xport.
    Open iGuidance outside of RR. Go to tools/GPS Options/com port and select the first output port selected in Xport per the above. Exit iGuidance. Go into RRConfig and in the GPS section put the number of the second output port in Xport per above. Save config. Finally, go to Webtracker and put the last output port in Xport per above. Save config and exit Webtracker. All should now work.
  6. #176
    Jun 2005
    Queens, NYC
    OK...
    W3B, my system has 2 serial comp ports
    KB, thanx for the info... Ill do as told..
  7. #177
    Jun 2002
    Virginia
    Just a reminder to make sure xport is not running when you have iGuidance auto detect the com port per above.
  8. #178
    Jun 2007
    nevermind...i got it to work.
  9. #179
    Apr 2006
    hey guys, what's the highest upload/save frequency you use? meaning most spaced out. Like every hour or whatever...
  10. #180
    Jun 2002
    Virginia
    Quote Originally Posted by W3bMa5t3r View Post
    I'm using 60,000. That works pretty well for me.
  1. tracking police gps
    By geoff897 in forum GPS
    Last Post: 09-10-2010, 11:43 PM
  2. need a gps tracking solution cheeep
    By L33TZOR in forum GPS
    Last Post: 09-11-2006, 07:53 AM
  3. Interesting GPS tracking software
    By Tred in forum Software & Software Development
    Last Post: 10-26-2005, 08:59 PM
  4. GPS Tracking
    By OriginalNick2 in forum Centrafuse
    Last Post: 01-21-2005, 04:38 PM
