Page 20 of 36 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 191 to 200 of 354
Thread: W3bTracker - GPS Tracking & Secure Location Marking (also offering Mologogo tracking)
  1. #191
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    for the error, what comm port is your gps coming in on? are you using a splitter? if so, what are your output ports?
    to stop the auto upload/connect to internet, set track=0
  2. #192
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by W3bMa5t3r View Post
    I'm using xport3 and have been for some time, I have it set up as follows.
    com3=input
    com6=W3bTracker
    com7=Iguidance
    com8=Roadrunner
    com9=GATSOhunter
    inav, rr and gatsohunter is working just fine...
    ok thanks, I thought it would stop tracking totally then and not even create a log file!
    Swedish site for CarPC's
    http://www.bilpc.info
  3. #193
    Apr 2006
    Quote Originally Posted by Naesstrom View Post
    com3=input
    com6=W3bTracker
    com7=Iguidance
    com8=Roadrunner
    com9=GATSOhunter
    well if your settings are like you have them posted a few back and here, you need to change your comport in the ini file to 6... that error is because it's not getting a valid connection to a gps com port.
    the logging should work so long as savetxt=1
    //I'm fixing lots of existing issues with the new version, like the comport errors, if it's invalid, it tells you and makes you select a valid one, but it'll be a lil bit longer before I release it cuz I'm workinga few other things out w/ it.
    now off to bed I go.. lol working tonight.. fun fun... later....
  4. #194
    Apr 2006
    Sydney, Australia
    Signed up, wanting to try it out..Will be a while before I get this up and running but looks promising, great work W3bTrack
    PEACE
    Kosti
    New Car PC Build list in progress
  5. #195
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    W3bMa5t3r - Some further thoughts for functions when its at a skining point...
    Upload on Upload off ( ie you want to pause sending the logs up )
    And three diffrent tracking modes...
    On - Tracking as is now - full on tracking / loging etc
    Private - Full tracking but all tracked logs are kept private and not viewable by any one else at all
    Off - Off
    You could expand if you really wanted to too Groups as well where tracking for only certain groups ( ie friends etc ) is active but not viewable by any one else...
    Also - is it possible for this app to out put the date such as location / speed etc to Roadrunner ? This way Skins can be updated if your not using say Freedrive and progs like RRGastoHunter can grap their data from RR rather than yet another app ?
    Terran
  6. #196
    Mar 2005
    Sweden/Vaxjo
    Hi again!
    I changed the ports between those 2 posts so it's using it's own but I still got the error...
    I shut down all the other apps that used xport and changed the tracker software to use RR's port and then I just get the $time error, any clue what might be the problem giving me that... the error message is true jibberish for me...
  7. #197
    Apr 2006
    yeah the $time error code is a coding mistake on my part. I've made lots of'm as this is my first 'real' program lol. The new version should resolve most of these issues.
    a side note, someone from Thailand is trying to locate my w3btrack/w3btracker source code and/or hack it (it's not out there folks). all I can say is WOW! I'm honored lol. though honestly... if you need MY code to make an application like this, you must be reallllly bad off. You 'might' want to see the paragraph above... (though what I don't get, is if you can work with source code... you should be more than capable to build your own... )
  8. #198
    Jan 2003
    W3bMa5t3r - Another thought.... if you want to log acuratly you need an acurate time on the PC.
    Why not auto set the time on the PC by using the signal from the sats to make sure its bang on ?
    Terran
  9. #199
    Apr 2006
    Actually the time used, is pulled from the sats, but the error above is from a lack of error checking on my part... lol. When it's parsing the gps sentence for the UTC time info, if it's not there it 'sometimes' dies... instead of just setting a null time and continuing on. This usually happens when the gps receiver hasn't received a good lock yet. This will be fixed in the next version. I'm making sure I've got error checking on all I can... hopefully I don't miss anything, but if I do I know you all will let me know
    Cheers
    The W3bMa5t3r
  10. #200
    Apr 2006
    Oh and does anyone know of some GOOD FREE gps data simulators? There's only so much I can do in a 'secured' enviroment, since I can't pull signals and all lol. The one simulator I've been trying to use doesn't seem to send to a readable port... even Xport doesn't see it.
    /if not I'll be off tomorrow so I can pull some signals... lol
  1. tracking police gps
    By geoff897 in forum GPS
    Last Post: 09-10-2010, 11:43 PM
  2. need a gps tracking solution cheeep
    By L33TZOR in forum GPS
    Last Post: 09-11-2006, 07:53 AM
  3. Interesting GPS tracking software
    By Tred in forum Software & Software Development
    Last Post: 10-26-2005, 08:59 PM
  4. GPS Tracking
    By OriginalNick2 in forum Centrafuse
    Last Post: 01-21-2005, 04:38 PM
