Page 21 of 36 FirstFirst ... 111213141516171819202122232425262728293031 ... LastLast
Results 201 to 210 of 354
Thread: W3bTracker - GPS Tracking & Secure Location Marking (also offering Mologogo tracking)
  1. #201
    Apr 2005
    Queens, New York
    cant u just use iguidance? Create a destination and start a "demo"... maybe that would work no?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  2. #202
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    Quote Originally Posted by Cheekz185 View Post
    I'm not sure... I need to be able to 'read' from a comm port, whether virtual or real... not sure if IG has the feature to output that... at any rate, I'm at work so I was trying to get something simple... and I don't have my IG discs with me lol... oh well... there are other things in the proggy I can work while doing my 'real' work LOL.
    Cheers...
    W3b
  3. #203
    Constant Bitrate urosbe's Avatar
    Mar 2005
    I have just successfully installed client in my CarPC and I successfully set up the program (locked satelites are 10 and it says Tracking...), but when I want to check on a server, there is no data (any point). I have a feeling that data are not sent from CarPC? I have also realized that even if I don't have internet connection avaiable, there is a "Tracking..." message. I also checked to write tracing in log, but the log is empty. So, I have GPS signal, because I see data from GPS, but tracking is not working for me.
    I am using GPSGate and Haicom GPS mouse. Virtual ports are for 1. Garmin emulator 2. Virtual port for Centrafuse 3. Virtual port for another program that uses GPS 4. Virtual port for client of this tracker.
    I think it is not a problem with GPSGate because I see correct number of satelites connected and data from GPS.
    By the way ... I am using WLAN if avaiable or GPRS dial-up via my mobile phone when WLAN is not avaiable.
    System: VIA EPIA EN15000,512 MB DDRII,M2-ATX,300GB HDD,XENARC 1020TSV,VoomPC case
    USB: Powermate,WinTV+FM,WLAN 54G,Bluetooth,Haicom GPS mouse SIRFIII
    Software: Windows TinyXP Rev06+MinLogon+EWF+HORM+Centrafuse 1.2
    Honda delSol project
    CarDomain
  4. #204
    Mar 2005
    Sweden/Vaxjo
    hi!
    Now I'm only getting the $time error and I guess that will be fixed in the next release...
    looking forward for it!
    Swedish site for CarPC's
    http://www.bilpc.info
  5. #205
    Apr 2006
    Hey guys, hoping to have a working version of the new rewrite up soon. I have entirely tooooo many projects going on... along with working 100-120 hours per 2 week period...
    Thanks for bearing w/ me
  6. #206
    Apr 2006
    Ok guys and gals?? I'm nearing completion of the new build. Just a few more things to touch up. I hope to finish it up tonight actually. I'll keep you posted.
    Cheers, The W3bMa5t3r
  7. #207
    Apr 2006
    It's available Download the new version here.
    Version 2.1.0.0 - A complete rewrite of the program for the most part.
    I'll be updating screenshots in the first post soon. Let me know of any errors you encounter.
    NOTICE!!! The config file and the program name have changed.
    It's now W3bTracker.exe and config.ini
    Most settings are set from the program, the only one that isn't is your baud rate which is set in the ini file. The default is 4800 which is normal, but some newer receivers use 9600. If this is the case with yours, just make the change.
    You no longer need the NetComm OCX or MScomm mess. Everything you need is included (I hope lol).
    The latest XPort3 is included in the archive as well.
  8. #208
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by W3bMa5t3r View Post
    Sweet, going to try it out this afternoon and see if I can find any bugs...
  9. #209
    Apr 2006
    Quote Originally Posted by Naesstrom View Post
    sounds good. I'm sure there are bound to be a few w/ the new rewrite... but hopefully I covered all the blatantly obvious ones .
  10. #210
    Apr 2006
    Skinning in the works...
    Setting in the config.ini file to control the visibility of the Title Bar and Menu Bar. Several skins included and you can create your own. Very simple design, but it should merge better into frontends than an ugly windows format
    Also adding the ability to upload previously saved data logs to the server, instead of being able to just upload the current one.
  1. tracking police gps
    By geoff897 in forum GPS
    Last Post: 09-10-2010, 11:43 PM
  2. need a gps tracking solution cheeep
    By L33TZOR in forum GPS
    Last Post: 09-11-2006, 07:53 AM
  3. Interesting GPS tracking software
    By Tred in forum Software & Software Development
    Last Post: 10-26-2005, 08:59 PM
  4. GPS Tracking
    By OriginalNick2 in forum Centrafuse
    Last Post: 01-21-2005, 04:38 PM
