2.1.0.5 is up.![]()
Hey guys.. I've made a change to the program to add the OS time/date and change the formate of the date to where it's DD-MM-YY instead of DDMMYY. The change was also made on the server, so any entries with the previous format won't be pulled (unless you manually type into the box in the DDMMYY format).
I'm gonna make a few more changes and then up the new version...
very very nice...sso whats new? Jut the mm-dd-yyy
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
yeah mainly the date/time right now, I wanted to get that working right so the date selection would work better... lol I'll be starting back on fooling w/ other things in a lil while... tonight...
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
well I made a few changes on the server. If you don't have a date selected, it will show the last upload points, the number you've selected. If you have a date selected, it will show you the points from that date...
off I go to try and make the program a bit smarter... lol later...
/edit.. lol haha I didn't even see that last post. I just noticed it myself when I logged in so I made the change. You're good to go mate![]()
-=-=-=-=-=-=-=-=-=- VERSION 2.1.0.6 -=-=-=-=-=-=-=-=-=-2.1.0.6 has been uploaded.
Auto-Caching while LiveGPSTracking upon loss of Internet Connection. Uploads cached data upon reconnection.
another config.ini file setting: pingimage=http://news.google.com/images/cleardot.gif
Made another change to the server... Your route is now marked by polylines / a red line from point to point... also the points are now sorted by date/time of actual point vs being shown in descending uploaded order. To make use of all the new features, it's definitely best to upgrade to the latest ver of W3bTracker...![]()
damned, this is looking better and better...
I still havn't got it to connect to the GPS though, Tried changing the com port today but still no connection as it seems!
as I said earlier I can see the gps data in xport and the radiobutton infront of the tracker com is marked so it's clearly connected to xport...
is there some kind of debugging mode that I can enable, maybe that might reveal whats stopping it from getting the coords!
Swedish site for CarPC's
http://www.bilpc.info
