Page 28 of 36 FirstFirst ... 18192021222324252627282930313233343536 LastLast
Results 271 to 280 of 354
Thread: W3bTracker - GPS Tracking & Secure Location Marking (also offering Mologogo tracking)
  1. #271
    Apr 2005
    Queens, New York
    Ok...I just added a perm point for the first time...it does not seem to show up! Also is there a way to configure a specific location to zone in on when 0 points are chosen..WHen i choose 0 points it goes to Washington...
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  2. #272
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Guest Login should be working now. Cheekz, sent you a PM about the perm point.
    As far as having 0 points and centering on Washington... When the map loads, it needs a center point, which is usually set as your last uploaded point. I'm gonna make some changes to where you can enter a lat/lon as your HOME. and if the option is set, that will be loaded last and your page centered there. Should be up before tooo long. Dang it... I need to work on the software too.. grrr lol too much to do and too little time. Well let me get off here and back to it.. later...
  3. #273
    Apr 2006
    Washington, DC
    Ok guys... The "Home Point" feature is now available. To set your Home Location, click on the map where you want the map to center. Click on "Set Home".
    If you want the map to auto center on your Home Location, check the AutoCenter @ Home checkbox. This works for all your maps, with or without points. When your map loads it will center on your Home Location.
  4. #274
    Apr 2005
    Queens, New York
    Quote Originally Posted by W3bMa5t3r View Post
    Its not working for me... any1 else get this working?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  5. #275
    Apr 2006
    Washington, DC
    Quote Originally Posted by Cheekz185 View Post
    IDK man, I've got it working in FF and IE... and looking at your account, your info was saved correctly... is the browser giving any errors? Which browser are you using?
  6. #276
    Apr 2005
    Queens, New York
    I tried it in IE and Firefox....no errors just when I click o points it centers in on Washington still...
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  7. #277
    Apr 2005
    Queens, New York
    When i hit "Set Home" it automatically re centers at Springfield...
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  8. #278
    Apr 2006
    Washington, DC
    Found it.. I think :-\ Give it another go.
  9. #279
    Apr 2006
    Washington, DC
    For those of you using the mologogo tracking. That feature should now be working again, and has basically the same features and functions as the normal W3bTracker page.
    The Perm Points and The Auto-Center on Home features/settingws are also shared with the other maps.
    You can use the KML and Traffic Overlays now, along with selecting the number of points and date to show.
  10. #280
    Apr 2006
    Washington, DC
    2.1.0.8 has been uploaded.
    Changed part of the GPS Sentence recognition function. I'm "hoping" this helps with the guys that have working gps data for other programs but W3bTracker just sits there. It shouldn't affect the guys that the program is already working for.
    As Always, Check the config.ini file.
    Let me know...
  1. tracking police gps
    By geoff897 in forum GPS
    Last Post: 09-10-2010, 10:43 PM
  2. need a gps tracking solution cheeep
    By L33TZOR in forum GPS
    Last Post: 09-11-2006, 06:53 AM
  3. Interesting GPS tracking software
    By Tred in forum Software & Software Development
    Last Post: 10-26-2005, 07:59 PM
  4. GPS Tracking
    By OriginalNick2 in forum Centrafuse
    Last Post: 01-21-2005, 03:38 PM
