Page 29 of 36 FirstFirst ... 192021222324252627282930313233343536 LastLast
Results 281 to 290 of 354
Thread: W3bTracker - GPS Tracking & Secure Location Marking (also offering Mologogo tracking)
  1. #281
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    If the dark gray outlines/borders on the website are a bit much for you, check out your account settings for a few options. These will be expanding over time.
  2. #282
    Raw Wave
    Jun 2002
    Virginia
    I was able to get my points to show up. Only issues now are:
    1. The client doesn't show the number of sats even though RR shows that I'm locked onto 8+.
    2. The client doesn't do an upload immediately, but waits for the specified interval before doing the first upload.
    Feature Request: I don't know if this would be easy or even possible, but how about numbering the points in chronological order so one can easily track the route sequence? It would be ideal if the numbers appeared above the points on the map, but if they appeared in the popup only that would be helpful also.
  3. #283
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by W3bMa5t3r View Post
    2.1.0.8 has been uploaded.
    Changed part of the GPS Sentence recognition function. I'm "hoping" this helps with the guys that have working gps data for other programs but W3bTracker just sits there. It shouldn't affect the guys that the program is already working for.
    As Always, Check the config.ini file.
    Let me know...
    nice, this seems to have fixed my issue with it not getting data from the GPS... and nice timing... went back home again (1000km/12˝hr) today and recorded most of it...
    Uploaded it and got some
    Code:
    Line Inserted.
    Error inserting Line.
    Line Inserted.
    Line Inserted.
    first but after that most of it got "inserted" and it deleted the .txt file... only thing is that I don't have any dates on "my" page and no points are showing up...
    btw, nice job with the themes!
    Swedish site for CarPC's
    http://www.bilpc.info
  4. #284
    May 2006
    Calgary, Alberta
    How much data does this ping? I'd like to use my Blackberry as a modem on an upcoming cross country trip but I only have a 5 megabyte plan per month for data.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  5. #285
    Apr 2006
    Washington, DC
    Upped a new version. It should help with the sat number (or provide a solution... :-\ ), and the occasional erroneous gps data sentences. The upload on start is and has been implemented, but was only on program start. It will now reset that variable if you Stop LiveGPSTracking, so that the next time you Start LiveGPSTracking, it will upload on start.
    For incremental numbered points on the map, or at least start and finish points, I'll see what I can do.
    @ Maheriano, you can use this client in the offline tracking/logging mode and just upload the points (GPSTrackingLog.txt) to the website later on once you have a more suitable data connection if you are worried about going over on your BB's data plan.
    @ Naesstrom, you have a PM
  6. #286
    Mar 2005
    Sweden/Vaxjo
    Upped a new version. It should help with the sat number (or provide a solutioin... :-\ ), and the occasional erroneous gps data sentences.
    Damned m8, you're on fire, or atleast your fingers must be... coding that fast
    The upload worked great right now... I should have set the time between tracking a bit further apart though... 2600+ points in one track didn't work all that good... think I'll go in and delete some of them so I can see the entire trip...
    going to try the new version today!
  7. #287
    Apr 2006
    Washington, DC
    Quote Originally Posted by Naesstrom View Post
    lol naa not so much. Most of the coding is done, just tweaking it so it provides better results now. Dang 2600+ points?? lol yeahh I think google's max for api maps is 1000 points. Glad it's working for you though
  8. #288
    Apr 2006
    Washington, DC
    Hey guys, the InfoBox Popups for your points now have some added info
    Point # and Start/Traveling/End
    Enjoy.
  9. #289
    May 2006
    Calgary, Alberta
    I'd like my family to be able to follow me real time though.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  10. #290
    Apr 2006
    Washington, DC
    Quote Originally Posted by Maheriano View Post
    Understandable. Well, the amount of data used would be determined by the interval used, which is adjustable from 15 seconds to 1 Hour.
    I'm not 100% on this, but for each interval, each upload/submission is ~ 315-630 bytes, each ping ~42 bytes.
    Hope that helps. Some of the other guys might be able to tell you how much data they actually use for the intervals they use...
  1. tracking police gps
    By geoff897 in forum GPS
    Last Post: 09-10-2010, 11:43 PM
  2. need a gps tracking solution cheeep
    By L33TZOR in forum GPS
    Last Post: 09-11-2006, 07:53 AM
  3. Interesting GPS tracking software
    By Tred in forum Software & Software Development
    Last Post: 10-26-2005, 08:59 PM
  4. GPS Tracking
    By OriginalNick2 in forum Centrafuse
    Last Post: 01-21-2005, 04:38 PM
