Page 7 of 36 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 354
Thread: W3bTracker - GPS Tracking & Secure Location Marking (also offering Mologogo tracking)
  1. #61
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    Quote Originally Posted by Cheekz185 View Post
    WEll I have to say that it does work now with xport3. Im glad about that... But how does the tack to log work? Is it all manual or does it automatically log and then send the data when u get an internet connection. Also the gps connect/disconnect does not work it is just red all the time. But when i first open the APP it flashes green once and thats it!
    WHEWWW lol I'm glad it's working for you The track to log can be automatic if you set the settings in the menu bar at the top. It will start logging when the program is run. Otherwise you have to press the button Track To Log. If you save an offline log, when you do have connection you just have to select UPLOAD LOG TO SERVER, from the top menu
    The gps connect/disconnect isn't really that per se. It's actually the buffer for the received data from the gps receiver. So if you're connected, it will be green, UNTIL you start tracking or logging, then, because the program is using the data, it will be red or alternating between the two. If that's the case, you'll know you're connected because you will be seeing the GPS data sentences in their area. Hope that clears that up... Let me know if you encounter any bugs/errors... I tried to run it every way possible to squash any, but someone will always do something I won't have foreseen..
    Later...
  2. #62
    Apr 2005
    Queens, New York
    Well i went to school today, I test the GPS log and it worked! BUT The time it took to upload the log was god awful. It took about 8-10 minutes to upload the log. I went to school from my GF's house which roughly takes 20 min one way. So it was about a 40min trip total that was logged. And it really took a long time. Is that supposed to be like that? Or is there any way to make it upload faster because the size of the log file was only 14kb.
    What about creating a database on the server that STORES your trips like on a calendar. Lets say Today March 13 u had 3 trips....u would click on march 13 and it would list the 3 trips like Trip 1 / Trip 2/ Trip 3 then click what ever trip and it would show u the route. Maybe by just uploading the saved LOG file itself to the server, it would go much faster!
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  3. #63
    Constant Bitrate Playerbeat's Avatar
    Apr 2005
    San Jose, CA
    working good for me. I'll go for a ride later for a better test. By any change can you make the program able to hide to the system tray? Oh and when I click on the points on the Google map it brings up a blank notification area. Would it be possible (and not time consuming for you) to send time, date, speed.... to that area for each point? Anyways great job. I'd like to see someone try and steal my car this time.
    7" TouchScreen Carputer
    Rockford Fosgate 1501BD and Rockford 551s
    12" MTX 9500 in a SS* or a 12" Brahma in a SS*
    ZAPCO COMPONENTS in front and RFs in rear
    2 YellowTops and a 200amp Iraggi Alternator
    *Snell Shell box from nolteaudio.com
  4. #64
    Apr 2006
    Quote Originally Posted by Playerbeat View Post
    Glad it's working for you. I'll work on adding the minimize to tray feature tonight along with seeing about the offline upload to work faster or have an actual upload on the server... or something. I'll think about it...
    As far as the google map piece... that was working but somehow I broke it... I'll get it fixed. It was supposed to display your username, speed, time, etc... I'll see what I can do to get it working again...
  5. #65
    Apr 2005
    San Jose, CA
    Sounds good. I just went a little drive a notice a clicking sound every time it uploads data. I thought I was crazy at first, but it seems to be coming for the app.
  6. #66
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    It works!! Just tried v1.8 in the car and it worked! Haven't played with the uploading log feature yet, but the normal operation works fine with xport here.
    Question: On the website map, is there supposed to be any info in those dialog boxes that pop up when clicking on one of the track pushpins.
    Wishlist: - Have the ability to allow someone to view my position on the website without having "password/username" combo..... Like a checkbox on the site or something on an "admin" page that I can check to allow/not allow someone else to just go to my specific address to see where the car is at.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
  7. #67
    "Speaker of the Truth" veedubya's Avatar
    Nov 2001
    Great seems to be working with my BU-303 and my "work supplied EVDO card"
    Great Google Map application!!! 2 thumbs up
    Wishlist: smaller pushpins (probably not achievable) and a Network link to add to Google Earth
    "Geeks dont need girlfriends we can ping ourselves"
    Sony Vaio 2Ghz 40G HHD, Routis 2004 GPS, 7" VGA TS Lilliput, BackUp Camera running RoadRunner with Simplistique Skin.
  8. #68
    Apr 2006
    Ok guys, got the info boxes fixed. Seems when I redesigned the map views and made the background black, with with text/font white, the google map used the white font as well so the text was actually blended into the info box. So I've adjusted it to be black for just that area and it's all good now. I'll be tackling all the other things... stay tuned
  9. #69
    Apr 2006
    Hey guys... Since there was a request to allow others to view your map without using your credentials, I've added that feature to your pages. Just select allow public view and hit submit. It'll show you what mode your map is in. For the 'guest' to login, they need to click on the 'guest login' link from the main login page. You'll need to give them your username, but that's it. If you haven't set your map for public viewing they will get an access denied. Let me know what you think. I'm working on the other requests... let me know if there's anything else you can think of...
    Cheers... The W3bMa5t3r
  10. #70
    Newbie FalconX's Avatar
    Dec 2006
    Athens - Greece
    I installed it home and it works perfect. I'll also try it in the car.
    Great man!!!
  1. tracking police gps
    By geoff897 in forum GPS
    Last Post: 09-10-2010, 11:43 PM
  2. need a gps tracking solution cheeep
    By L33TZOR in forum GPS
    Last Post: 09-11-2006, 07:53 AM
  3. Interesting GPS tracking software
    By Tred in forum Software & Software Development
    Last Post: 10-26-2005, 08:59 PM
  4. GPS Tracking
    By OriginalNick2 in forum Centrafuse
    Last Post: 01-21-2005, 04:38 PM
