Really nice, no quarks in the 30 seconds I played with it. =D
Hi,
I thought that OSK would be very difficult to use on a small screen in a car, so I have developed Virtual Keyboard. The keys and the key layout is generated at runtime. It should be OS language independent. Can someone test it and let me know what you think about it. I haven't tested it on Touch screen but if the Touch screen driver just acts as like a mouse it should not have any problem
When you run the application a keyboard icon is placed on the top left of the screen. Clicking that shows and hides the keyboard. The icon always stays on top. To close the application right click on the icon
Following fixes has been made
1.0.0.2:
1) Icon Drag can be disabled from the ini File
2) Hide Btn available on the keyboard (user Defined Position)
3) generation of Dead keys.
4) icon Dragging problem
5) Save last position of Keyboard on Exit.
6) generation of chars when shift key is clicked and caps lock is on
1.0.0.3:
1) On Clicking the Icon, the focus is not lost from the current application
1.0.0.5
1) The Keyboad Dragging can also be diabled
2) Size in percentage can be set in the ini file
http://voices.techworldonline.com/co...d V1.0.0.5.zip
Regards
satish
Nice program. I played a while with it and i like it.
Would be nice if you could also save the position of the
keyboard on exit, and restore the keyboard there when started.
When all keys are defined, there will be a problem moving the keyboard
using a touchscreen (no place to hold the keyboard with a finger)`
There are a few little problems ;
the shift-6 character ^ is not on the keyboard but generates
a ^ when pressed.
the \ character is twice defined.
Why are the F6 -F12 keys not defined ?
Sweet OSK!!! I like it!!!
New CarPC on the way again I think. I miss my old one!!!
Clicking or dragging the icon causes the icon top left corner to jump to the mouse pointer.
Other than that, pretty cool.
[H]4 Life
I'm a lesbian too.
I am for hire!
I agree much more useful than XP OSK, I will try it tonight on a touchscreen.Originally Posted by PiR-P3
^ was there for me
There was some kind of odd problem that caused all of my open windows to minimize and then none would restore. I could click them in the taskbar, but the wouldn't pop back open. I had to ALT-TAB to one to get it to restore and then they were all OK again.
Nice proggie... just what i was looking for (for once me laptop and screen finally make its way into me car....)![]()
Very nice... impressed![]()
Very nice. All keys defined (exp F6-12) correctly for me. ^ works and only one \.
I asume I can 'skin' it by just swapping the Jpeg? Keep this thread updated with your next update.
Will def be using it if i ever fix my screen...
Your OSK looks great! I just have small request. Is there any way you could add the ability to remove the dragging function of the small keyboard icon? A simple switch in the config file would be great. I just don't want to accidentally move the icon to launch the app while I'm driving.
Is the source code available?
Thanks!
Andy
Could be just my setup, but I cannot move it to my secondary display. It'll drag over there just fine, but when I release the mouse, it jumps back to primary.
