Page 11 of 20 FirstFirst ... 234567891011121314151617181920 LastLast
Results 101 to 110 of 193
Thread: Need Testers for Mappoint embedded Navigation System
  1. #101
    I got error message when starting dashPC:
    "The Requested member of the collection does not exist. Use a valid name or index number"
    What i'm doing wrong ?
  2. #102
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    Name suggestion: VNAV
  3. #103
    Variable Bitrate SilentAdmirer's Avatar
    Jul 2003
    Linz Am Rhein , DE
    @karhu
    I cannot tell you out of my head what the problem could be rite now.But the following could be the reason.
    Do you have mappoint 2002 or higher installed on you PC ?
    Do you have all the required dll's for the application in the application directory ?
    Do you have MS SAPI 5.0 or greater installed ?
    BTW which OS are you using ?
    Regards
    Satish
  4. #104
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by suprthug8d
    For example, white would be 16777215 instead of FFFFFF. So tried to find a hexadecimal to decimal converter, but that didn't help too much. When i finally found a converter it reported white at 255255255. So the colors are a little off.
    Quote Originally Posted by CdRsKuLL
    jto convert hex #123456 to dec colours, just use the calc in windows in si mode, take the first 2.. ie FF input them as hex, and click Dec, it will say 255, then just do the other 2 pairs.
    You need to put the whole number in, not the pairs seperately.
    i.e click Hex, enter FFFFFF, click Dec, = 16777215
  5. #105
    Jan 2004
    Cannot start DashPC
    Hi, i cannot start DAshPc , it seems that the map is not loaded/created. But i don't have now GPS Connected.
    System is
    MAppoint Italian 2004
    WinXp Italian
    How can i know if i have installed the speech system. Is there a link to download ?
    Many thanks for your beautifoul work.
    Maurizio Binello
  6. #106
    Jan 2004
    Dash Pc
    I am a Senior Borland Delphi programmer. If you need something for the project tell me (activex o whatever).
    Maurizio Binello
  7. #107
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Laidback, no your wrong, to calc hex colours into dec colours you need to break them down.. each pair is a colour.. ie..
    #FF0000 is RED
    255000000 is also RED
    you need to split them into pairs, FF FF FF is white. Thats why 255 255 255 is white.
    The # symbol tells you its in Hexidecimal (Base 16. 1 to 9 then a,b,c,d,e,f)
    Eash pair is one colour, Red, Green, Blue. so #00FF00 would be Green. also 255000 is also green in decimal. As is #0000FF is blue, and 255 is blue in decimal..
    If you need me to write a converter let me know, I'm sure theres plenty around already.
    if you do 255x255x255 thats the number of colours you have to display 16581375 different combinations :-)
    Steve
  8. #108
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by elica2099
    System is
    WinXp Italian
    Maurizio Binello
    If you don't have a GPS to connect try downloading a GPS simulator. This allows you to make a fake GPS device to test in the house.
    You need: http://www.lichtenheld-mch.de/GPSsim_E.htm - 'GPSSIM' and either a null-modem cable between two serial ports (One for GPSSIM to send the fake GPS down and one for the navigation program to use) or a trial for a virtual version such as 'VSPD' - download a trial from http://www.mks.zp.ua/vspdxp.php
    GPSSIM does come witha sample GPS track, it is not too hard to record a few of your own for testing however.
    If you ever need it the speech SDK is available from http://www.microsoft.com/speech/downloads/sdk51
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  9. #109
    Jul 2003
    Linz Am Rhein , DE
    @CdRsKuLL
    LaidBack is right. In Windows the color is a decimal value of the hex 0xbbggrr. Enter the value in the same format in Hex and convert to decimal and then you have the decimal value of color
    red = 0x0000FF = 255
    Green = 0x00FF00 = 65280
    Blue = 0xff0000 = 16711680
    and white = 0xffffff = 16777215
    Nice idea about the dat file will do some thing like that in the next release due on friday if possible
  10. #110
    Aug 2003
    Warwickshire, UK
    @SilentAdmirer
    Is it possible to add an option in the .ini file to turn the 'Home' icon which make s the program quit on or off, I would like to just run this app on it's own for the moment until CarPC is properly installed into my new car
  1. Replies: 7
    Last Post: 11-09-2009, 09:19 AM
  2. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  3. X-MP3Pad: Beta testers needed... Please read!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 08-22-2002, 12:55 PM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
