No, so the home icon doesn't show, I.e. so it is harder to accidently quit the program.Originally Posted by SilentAdmirer
@stevig
An option in which you click on the home icon and it does not quit the program ?
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
sorry LaidBack.. seems u are right.. hope i didnt cause u any headache's ;-) I'm installing this soft right now.. hope to have a play this afternoon.
@stevieg That can be done but then how do we quit the app ? Or do you think its a better idea to put the quit button in the control panel and move any button form there to the main screen ?
From a users point of view, I think it would depend on whether your using it with or without another application. If it's running under MediaCar etc, then obviously the 'Home' button is best where it is, but if it's running on it's own then the quit button would be great in the control panel.Originally Posted by SilentAdmirer
@stevieg
That would not be that easy as the control is a different window. I will see what else can done.
I think the quit button should be far less prominent. IN most cases, people will not want to quit, unless as stated, they are running it under MediaCar etc.
How about we work with stevieg 's first suggestion Quit on/off via ini file.
If in Ini file Quit is off. the quit button will be on the control panel and the gamma button on the main screen.
or else will be as it is now. Got a nice idea to implement it fast .
Sounds good, thanks!
But once it works 'embedded' in MediaCar, you would use the MediaCar quit button to shut DashPC. So the exit button wouldn't need to be on the front page.Originally Posted by skippy76
