Page 1 of 20 1234567891011 ... LastLast
Results 1 to 10 of 193
Thread: Need Testers for Mappoint embedded Navigation System
    Variable Bitrate SilentAdmirer's Avatar
    Jul 2003
    Linz Am Rhein , DE
    Hi,
    I have just finished testing Alpha version of Voice guided Navigation system. I need some testers for testing the alpha version. I don't want to release till some of you have tested it and given a green signal. As you must be aware that Mappoint does not support turn-by-turn direction by default I have found a work around and seems that it works most of the time, expect when the turns are very closeby its not very accurate. Also its not easy to find wheter you made the turn or not. Here is the list of main feature it supports as of now.
    1) auto zoom in at higher speeds.
    2) Voice guidance for the next turn when you are near the turn , the distance depends on your speed. Also if you are using winAmp it will pause it for the guidance and resume again later
    3) Configurable Autorouting feature
    4) Voice commands support:
    "Computer" to get into the listening mode
    and the commands are
    a) Zoom in
    b) zoom out
    c) Guidance off
    d) guidance on
    e) When is the next turn
    f) Reroute
    eg "Computer Guidance off" will switch off the voice guidance
    5) Supports skin
    Presently compiled and tested in W2K
    For testing you will require the following
    OS: win2k/xp with speech engine installed (haven't tested on win98 so not sure)
    Harware : GPS mouse and of couse the carPC
    software: Mappoint 2002
    Also you will need either a keyboard or OSK to enter the route.
    You can now download it from http://212.19.79.238/~satish/
    ThanX to Skippy76
    Warning: Its a alpha version so expect a lot of bugs
    Regards
    Satish
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Cool I sent you a PM. Will this be able to work with MediaCar?
    Jul 2003
    Linz Am Rhein , DE
    Yes as an external application it should work . The application will be hosted on Skippy's site soon .
    Jul 2003
    Linz Am Rhein , DE
    The new version is available at http://212.19.79.238/~satish/
    thanX to Skippy76 to make a web space available to host the files.
    New commands
    a) computer Take Me home (In the ini File enter the complete home address. )
    b) computer what is my current speed.
    also distance remaining from main destination bug has been solved .
    regards
    Satish
    Maximum Bitrate bertybassett's Avatar
    Sep 2003
    Gloucester (UK)
    wow this works like a charm. This is the best thing to happen to mp3car since media car. PM coyote and get this intergrated into mediacar as the defualt mapping software.
    Sep 2003
    Gloucester (UK)
    worked fine with mappoint 2004 and XP but only tested quickly, say 5 mins
    Jan 2004
    California
    I would really like to see this integrate within MediaCar as well. What do you think about that SilentAdmirerer?
    Jul 2003
    Linz Am Rhein , DE
    Plan is to help any one to integrate it any software . So that the end user gets what he wants for free
    Jun 2003
    Memphis - TN
    Im up for it...
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Jul 2003
    Linz Am Rhein , DE
    a new version should be available to download from skippy76's site by tomorrow evening with more features like current speed,direction heading ,ETA and some bugs removed.
  1. Replies: 7
    Last Post: 11-09-2009, 09:19 AM
  2. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  3. X-MP3Pad: Beta testers needed... Please read!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 08-22-2002, 12:55 PM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
