No??Originally Posted by telstargb
Don't know if this is possible, but figured I would ask. Currnetly VOICES controls the winamp controls for things such as next song, pause song, stop song, etc... This is perfect for integrationn with MediaCar because it uses Winamp. Is it possible to have an option when you load to have it control the active player from FrodoPlayer as well? Basically so when you are running VOICES as your external GPS software from FrodoPlayer you can contnrol the audio functions from there. The volume should already work, since it controls the master value.
Mondeo 1.8 Zetec : Epia 800 : 60gb drive : Lilliput 7" VGA : Sapphire USB GPS : Opus 90w : WinXP : Road Runer : Destinator
of course yes . Will do that. Just back from a hectic training now back to VOICES from tomorr0w . New version will be released soon
It would be very helpful, if VOICES could not be called several times. Thus in each case instance of Voices runs ...
Regards
Oliver
http://picasso.zoffi.net
This really isnt a request more like a dream I think.. but anyway..
Wouldnt it be cool, to have a program that would start your car.. control your Ac, and do what V.O.I.C.E.S. does..
I know that one company for some expensive cars created a Voice controlled Climate Control and Music Control program. Think it was more of a headunit.. a rather large headunit..
But Ill stop rambling now..
05 Acura RSX Type S
- Back to the Planning Stage -
ETA: ???
Sat:
We should develop something like this for voices
http://zoran-horvat.de/private/CarPC/default.htm
Note: incase that link is down...it is software to control a mobile phone via bluetooth.
Also of mention would be VoIP for use with a 1x broadband card!I'll have to look into what the bandwidth requirements are of VOIP. My understanding is it sits around 64kbps which most 1x cards are more than capable of.
Just a thought.
Asus Pundit Barebones PC
7" Lilliput LCD
P4 2.8ghz 512mb 120gb
Windows XP Pro, VOICES
Sony Xplode 10in Sub, Rockford 600w amp
Pioneer 6x9's and 4x6's, Kenwood 4ch amp
Black Widow Alarm with Pager
Here a desire, from which I believe that he is really usefull:
With navigation provided routes (as with MediaCar) load (in order determined be able to indicate pauses).
This feature offers evenly MediaCar, why I use it for certain purposes for navigation, although it is not equal VOICES in this regard - the navigation of VOICES is realy very good (much better then MC)!
If VOICES had still this feature of MediaCar, it would be nearly perfect!
Regards
Oliver
If I understand correctly, you want to be able to add pauses / stops / rests etc. to VOICES for your route.
06 Volvo XC90
Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
Car PC downloads: http://carpc.harteveldt.com/
Yes - this is right!
In MapPoint you can generate a route with all this things an than you can import/load this route in MediaCar. This wil be fine, if VOICES have also this feature :-)
Regards
Oliver
I was under the impression that if you add more than one place in VOICES it does this anyway; I am sure I did that the other weekOriginally Posted by skippy76
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
