Don't suppose you have something strange setup in MapPoint you you prefer not to be on Motorways...???
Printable View
@stevieg : Do you get the server busy after the calculation or during the calculation ???
During, as if the program is expecting it to have finsihed calculating the route by now. PC is 800Mhz Epia 256MB Windows XP so not that rapid - dont get the error on my 2.8Ghz laptop! On the machine it takes about 10-15 seconds to calculate the route.Quote:
Originally Posted by SilentAdmirer
One thing that is annoying about the Text to Speach Commands is that it reads the abrieviations of directions wrong.
For instance when it say RD it actually says R D. But when it reads AVE it says it incorrectly becasue it thinks that it is a word not an abrieviations.
Maybe there should be some sort of translator that would send Road to the Text to speach engine instead of RD and Avenue instead of AVE so that when it is reading the directions back to you the system is a little more understandable.
Another thing i am having a hard time figuring out:
How do i resize the map window? I want to cut down the Height about 50 pixles so that it is useable in media car
@anitmatter : I am working on the abrieviation list could you send me a list of the words you encounter ?
About the height, in the skin.ini try SizeX = 800 and SizeY = 550
Satish
if you are not contently with the default computer voice (SAM), loads other voices from Microsoft:
http://www.microsoft.com/reader/de/downloads/pc.asp
http://www.microsoft.com/reader/de/downloads/tts.asp
http://www.microsoft.com/msagent/downloads/user.asp
This works also fine in Englisch, German, French and so on (I presupposed so much intelligence that everyone loads itself its correct language package ;)
@zoffi I plan to work on the language package for commands and feedback. I have to find how to map voice commands dynamically to the app and for voice feed back I will need some help from you guys, will come up with a list for test version and later the voice fedback will be taken from the language.ini if it works as I have planned.
Regards
Satish
Great! If you have a new version - i will test it gladly :)
(up to now I have still none voice commands used - no microphone and the ambient noise are too loud - me are rather Buttons)
BTW: you need nevertheless always the correct voice-language-pack, because otherwise the discussion is dreadful ... SAM cannot speak German, or French - no, realy not! ;)
@bertybassett : Regarding the Screen Size in Media Car. Are you using it as an embedded application in MediaCar ?
@ozoffi : It will be some time before the new version is released. Have to take care of some bugs which are important and a lot of things lined up. I guess the new version would not be out for at least 8-10 days .
Regards
Satish
Take the time, which you need!
