Page 4 of 15 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 143
Thread: Official Bug reports.
  1. #31
    Low Bitrate telstargb's Avatar
    Aug 2003
    Leicester, UK
    Trying to use voices on Win 2k Pro, using Mappoint 2004 Europe. The map loads and the SatNav correctly locates my position, then I always immediately get a Program Error box with the following error message:
    "Voices.exe has generated errors and will be closed by windows. You will need to restart the program. An error log is being created."
    I cannot locate an error log anywhere. Any ideas anyone?
    Mondeo 1.8 Zetec : Epia 800 : 60gb drive : Lilliput 7" VGA : Sapphire USB GPS : Opus 90w : WinXP : Road Runer : Destinator
  2. #32
    Variable Bitrate SilentAdmirer's Avatar
    Jul 2003
    Linz Am Rhein , DE
    @telstargb Do yopu have SAPI 5.1 installed on your PC ??
  3. #33
    Aug 2003
    Leicester, UK
    Quote Originally Posted by SilentAdmirer
    Not sure - how can I find out? Not installed it separately, not sure if its installed by default with W2K.
  4. #34
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    @SilentAdmirer - Another bug connected to the 'Retry' Server Busy message when calculating long routes. Sometimes it also pops up many boxes with 'Unspecified Error'.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  5. #35
    Aug 2003
    Warwickshire, UK
    @SilentAdmirer - have you thought about a 'debug' mode that writes a log that we could send you?
  6. #36
    Jul 2003
    Linz Am Rhein , DE
    @ telstargb : I don't think its available on W2k by defalt you need to download it from Microsoft site. to confirm it you can check the control panel if there is a speech applet
    @Steve : I did send you a PM regarding it. I have made a seperate build for you to check.I did try to solve the problem but cannot test it on my PC as I never got this error in the first place.
    Regards
    Satish
  7. #37
    Jul 2003
    Linz Am Rhein , DE
    will have to do some thing soon about the log will start working on it.
  8. #38
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    I've played around with VOICES for a couple of days and have encountered this problem numerous times. I'll be on the road following the planned route, but Mappoint will show me just off the road. I'll get a rerouting local road message numerous times. Is there a way to adjust the sensitivity of the rerouting? It seems that Mappoint 2002 isn't as accurate as it should be. When I turn on the road that I live on it takes it about 20 seconds before it realizes that I'm on the road rather than an imaginary local road. Overall, I really like the program and the turn by turn voice directions work better than Destinator and occur at the perfect time!
    Thanks-
    Rick
  9. #39
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by rgardjr
    Thanks-
    Rick
    I'm using MapPoint 2004 and don't have that problem (except on Motorways) the GPS is accurate down to side of the road, and on normal roads re-routes perfectly; for example on a dual carriageway going the wrong direction it sends me up to the next place to turn round rather than just pointing me back the other way. Destinator however seems to 'lock' you onto the nearest road. Perhaps your GPS is badly positioned? I have mine mounted on my roof.
    I have to agree the turn by turn is perfect, I noticed the other day that if your going fast it tells you earlier! I tried Destinator the other day for the first time and it is no where near as good as VOICES, it gave me the directions much too late and I had to rely on looking at the screen rather than listening to directions!
  10. #40
    Aug 2003
    Leicester, UK
    problem solved - installed SAPI 5.1 & it now works fine
  1. Official Bug report
    By coyote in forum MediaCar
    Last Post: 11-30-2005, 03:50 AM
  2. Replies: 0
    Last Post: 03-05-2004, 05:24 AM
  3. bug: (me.org is down for me)
    By mutilator in forum Media Engine
    Last Post: 02-22-2004, 08:28 PM
  4. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
  5. Weird bug on vBulletin search
    By izaram in forum Off Topic
    Last Post: 05-15-2002, 01:56 PM
