Results 1 to 9 of 9
Thread: Voices Navigation Interface
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    I wanted to post with my recomendations on a menu interface for mainly SilentAdmirer but also for everyone elses input.
    SilentAdmirer has tasked me with creating a well thought out interface for Voices.
    After installing Routis 2004 (and being very pleased with it by the way) and looking at a few other Navigation packages i realized that the interface that VOICES needed had to be pop up menu driven. For instance look at these screen shots of routis
    Notice the small unobstrusive menu button on the lower left
    There should be a button like this for VOICES
    Then a Pop up Menu follows with large easy to read skinnable buttons (as I invision it for Voices)
    Then when you click on each buttin a series of Options follow as below
    Not all of the information or options will be the same but it will definatly be close...easy to navigate and structured. I think that there is a reason that every navigation application has used this method... becasue it works
    What do you guys think?
    Pictures curtisy of MikeH
    Variable Bitrate SilentAdmirer's Avatar
    Jul 2003
    Linz Am Rhein , DE
    thanX antimatter will start working on it rite now.Lets see what I can do about it
    Satish
    Jan 2004
    California
    You may want to evaluate the way that your skinning is done aswell . Percent as opposed to pixles is supporsed to be a lot easier to work with when having an interface with multiple variations in resolutoins (as is all applications)
    Elaborating on the menu idea and looking at your current skin I like the Full screen function and the ability to make the map take up all of the screen.
    I think that the The full screen function should toggle from full screen map mode to split screen with the driving instructions. By taking away the menu that slides up from the bottom and making it a pop up menu (like in the pictures) I think that it would definitly simplify things.
    We should come up with the a set of 6 or so general buttons and place all of the items within the property pages of the repective categories.
    Mar 2004
    AT/Vienna
    Have you this tested also on a 7" Display in your Car with a distance from for instance an arm length between eye and display? If you can read then the Button, without eyeglasses, and it on a Touchscreen also hit, it is large enough
    Regards
    Oliver
    http://picasso.zoffi.net
    Jan 2004
    California
    Have we tested what? We are designing this with the touchscreen in mind and I ahve a 7" touchscreen for beta testing as does most people here.
    Jan 2004
    California
    Here is the breakdown of the menu driven options that are in Routis/Iguidance. Customize these to the options that you have available in the Voices Nav App. I have insicated with italics the options that I think would apply with Voices and bolded the main menu buttons.
    Destinations
    Address
    Intersection
    Points of Interest
    Favorites
    Recent
    Route Options
    On/Off Buttons for Quickest/Shortest/Local/Major
    Reduce Turns enable/disable
    Toll Rodes enable/disable
    Carpool enable/disable
    Speed Alert
    number pad to enter in max speed
    checkbox to enable/disable speed alert
    Volume
    Mute button
    Test Button
    Volume Slider
    Map Options
    Show POI icons
    Map view 3D positions
    Map View Heading Up
    Map View Heading North
    Record
    Save your location and Route
    GPS Info
    Pop up screen with satilites locked/Longitude/Latitude/Alt/Speed/Compus
    I posted this information as a guide incase you havn't seen Routis or Iguidance.
    Cheers
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    I agree about pop up menus, tomtom works on the same.. but it doesnt have a menu button.. you just tap the screen and the menu appears
    I've been using Routis so I have a couple of suggestions that I think Routis lacks. Overall I think Routis is a very touchscreen friendly application, it's more features I'm thinking of.
    1. Routis has a box that displays your toute to a destination. It allows you to highlight each road. It would be great to be able to highlight the road and toggle it for avoidance. It gets dropped into a new window listing avoids. You can then on the fly move it from avoids and have it reroute. This is for when there's a traffic jam or accident and you want to hop off the highway to get around it then get back on the highway. So, this is partially interface and partially a new functionality.
    2. It would be nice to have speed displayed somewhere in the top or bottom bar that show your current street and your next street to turn at (rather than have to have the whole GPS data info box pulled up). There's plenty of room for some data in these bars.
    3. Around the edge of the map, there is an arrow showing north (if it's set to rotate). I'd also like one to show the bearing of my final destination in case I'm ignoring the route suggestions and just want to try to head toward my goal (maybe it already does this, but I don't see it).
    Ok, so I guess most of this is functionality but they all have GUI components . I've only used Routis and Mappoint so I don't have anything else to compare it to, but I really like the Routis interface and the way it minimizes the menus to use the full screen for a map.
    Jan 2004
    California
    Good comments
  1. Pioneer Aux interface.... wiring up ... how?
    By Kenny in forum General Hardware Discussion
    Last Post: 06-27-2009, 06:56 PM
  2. what is VOICES?
    By SilentAdmirer in forum V.O.I.C.E.S
    Last Post: 08-21-2004, 05:48 PM
  3. ultra tiny interface
    By skullman in forum Input Devices
    Last Post: 03-22-2004, 03:53 PM
  4. A few questions about an interface
    By naevity in forum Software & Software Development
    Last Post: 10-03-2002, 10:31 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
