Page 7 of 9 FirstFirst 123456789 LastLast
Results 61 to 70 of 86
Thread: VOICES Traffic Data
  1. #61
    Mar 2004
    This is an excellent idea, and will be a fantastic edition to Voices. Its too bad there isn't a national weather/traffic source out there. It would be very useful for many applications to have a database of weather/traffic/road conditions that could be used worldwide!
    Asus Pundit Barebones PC
    7" Lilliput LCD
    P4 2.8ghz 512mb 120gb
    Windows XP Pro, VOICES
    Sony Xplode 10in Sub, Rockford 600w amp
    Pioneer 6x9's and 4x6's, Kenwood 4ch amp
    Black Widow Alarm with Pager
  2. #62
    VENDOR - Centrafuse veetid's Avatar
    I got MapMarker to batch Geocode Intersections and its really accurate. Alot more than I expected. It was accurate enough to differeniate between the two sides of the Interstate/Freeway. I am going to try and get all the lat/long info for all of CA tommorrow. This same technic, if it works out, can be used for a lot of independent sites to gather information for other states.
  3. #63
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Cool, sounds grat. is MapMarker only for the US, as this would be useful for a lot of the european info sites
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  4. #64
    dont know if there is anything useful that you havent already found, but i came across this page looking for a new battery:
    http://www.ntb.com/trafficinfo.htm
    National Traffic and Road Closure Information
  5. #65
    Aug 2003
    Warwickshire, UK
    will check it out
  6. #66
    MapMarker is not limited to the US. It is global... It is pretty much the industry standard for geocoding. I just happen to have a copy of it, because we use it at work for geocoding lat/longs for appraisal properties. I work with a company that has the 2nd largest Database for appraisal data in the US. I hopefully can make a good easy system for geocoding with it, that way I can geocode stuff for people. Unfortuntately I couldn't give the software out. It takes about fifty security checks and all new licenses / mac addresses for the machines to install it. You have to get on the phone with them everytime you move it and I think the software cost around the range of over $100,000 (US).....
    One bad thing.... I am not sure if my company has the data for anything outside of the US.... I know it was about 7 cd's, but I will have to look into it.
  7. #67
    I finally entered in all of San Diego... It included 312 exits across all the freeways. I then ran it through mapmarker and it was able to find 72% of the intersections. So that left 89 exits off. I attached an updated image. I guess at this point I would have to get those 89 lat/longs individually (take forever) or just say 72% of the exits of a town is good enough.
    One thing I have noticed is that from a high view you can't tell the two different lanes on the interstate. You can't differniate between North, South, East, West. My idea was after I get the lat/longs I would need to determine if they are North, South, West, East and then offset them in the proper direction. Example: If you have a lat/long for a Interstate going South you would want to modify the lat/long to be offset to the left a little bit. That way it would actually sit a little off the Interstate to the left and so forth if you had one going North you would want to offset to the right a little bit.
    Just an update on what I found so far....
  8. #68
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by veetid
    With what you've done so far, would it be possible to generate a list of location names as they appear at the source with the corresponding lat/lon, then I can have a go at pulling the data in and tranlating the traffic data.
    PS What's the mappoint control based software in the screenshot?
  9. #69
    I solved the problem with the pushpins being too close together. I now take the lat/long and based on direction N,S,E,W I calculate an offset, which places the pushpins off the Interstate/Highway. Now you can see the difference in the direction. I posted a new screenshot. Now you can actually look at the 5 and tell if there is traffic on the North or the South, or Both.
    When I am done I will have an XML file that will have all the locations and exits of CA and there lat/longs and direction. I can then supply you with a piece of code that will show you how to update the speeds from a site. You can run that code as often as you like to update your DB. It is fairly simple code and should be easy to convert to anything.
    I will also talk with the VOICES man to let him know how I offset the pushpins and got it to seperate the directions on the map.
    As for the program I am using.... I wrote this whole thing in .NET C#. The mappoint control software in the screenshot is mine.
  10. #70
    Mar 2004
    Not sure if there is any way to extract this type of information...but i stumbled across this today:
    http://www.highwayconditions.com
    7" Lilliput LCD
  1. Voices Navigation Interface
    By antimatter in forum V.O.I.C.E.S
    Last Post: 05-14-2004, 07:49 PM
  2. Online Traffic Data (UK)
    By stevieg in forum Software & Software Development
    Last Post: 04-27-2004, 03:14 PM
  3. SPOT watch data in CarPC
    By Alric in forum Software & Software Development
    Last Post: 03-19-2004, 02:09 PM
  4. Offline Traffic Information
    By ukchris in forum Software & Software Development
    Last Post: 03-09-2004, 04:51 PM
  5. Cold hard drive fluid bearing data loss
    By Mikesz in forum General Hardware Discussion
    Last Post: 12-13-2003, 08:17 PM
