second method would be best
VOICES currently has a button that enables you to apply / remove the Gamma, providing a brightness control for use at night.
An automatic system would be a big advantage. There should be two options when applying an automatic switch:
- By time of day, manually configured for on and off.
e.g. gammaon=19:00
gammaoff=05:00
- By long and lat value, based on a sunrise and sunset calculation. Code for this can be found at:
http://personal.inet.fi/cool/jjlammi/rscalc_cpp.html
06 Volvo XC90
Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
Car PC downloads: http://carpc.harteveldt.com/
The first one is what other programs use and is manual and should be an option for those who dont have GPS...Remember not everyone ownes a GPS (yet)
I personally like the second option the best becasue it requires no setup from the user except for initial setup.
Good work
Both the options will be implemented![]()
Impressive! I think there should also be an option/voice command for a manual gamma change. I find that it not only depends on where the sun is at, but what i'm doing with the computer. IE. During the day its gloomy and i want it dimmed...i could say: 'computer dim display'
If its night and I'm watching a movie i may want it brighter so i could say "computer bright display"
etc...
Asus Pundit Barebones PC
7" Lilliput LCD
P4 2.8ghz 512mb 120gb
Windows XP Pro, VOICES
Sony Xplode 10in Sub, Rockford 600w amp
Pioneer 6x9's and 4x6's, Kenwood 4ch amp
Black Widow Alarm with Pager
"Both the options will be implemented "
Very good! I dont realy like automatics. Every time i will control the system ....
Regards
Oliver
http://picasso.zoffi.net
is there a way to add a shortcut on the desktop that can do this? like media car kindof has?
why not just link it to the headlight/dash light circuit? When you turn on your dash lights, it's typically low light or night time and the ideal time for the screen to dim...
Has anyone heard of any USB or otherwise connectable ambient light sensors for use with a notebook?
