View Single Post
Old 04-04-2007, 01:41 PM   #6
2k1Toaster
Fusion Brain Creator
2k1Toaster's Avatar
The store is hosted on different servers than the forum. I believe the store is offsite, while the forums are onsite.
But anyways, my point is you are not using a "minimal power setup". You are using a maximum power setup, with the minimal power input. The M2 can handle P4's and full on AMD's, but that requires the use of a laptop HD, low RAM, limited USB devices and next to nothing else being drawn.
The M2 is not reccommended to power high end setups. That is why it is only $80, and not $220. And a standard case will fit one of the opus power supplies I believe. But you usually select the components (like the PSU) over the aesthetics like the (case).
2k1Toaster is online now   Reply With Quote
