View Single Post
Old 05-04-2007, 10:33 AM   #40
swordfishunter
swordfishunter's CarPC Specs
My Photos: ()
I got my asio to work without crackles pops...
Was having the same problems as you, as well has hibernate problems... but this has been solved with devcon.
Anyway, the way to solve the asio problems is not with asio caps, but with 2 different plugins for winamp, one is the asio out dll, and the other is the asio plugin. Use the asio plugin to set the asio at 16 bit, 2-3 second latency, then use the asio out as the primary sound driver, and tick only gapless mode.
This has worked fine for a couple of weeks .... with no crackles / pops etc.... it only stutters with too many apps running so i've solved the sound problems, however, now my processor is too slow.
Give it a whirl
swordfishunter is offline   Reply With Quote
Sponsored Links
