View Single Post
Old 12-21-2007, 11:42 AM   #48
PPE
PPE's Avatar
My Photos: ()
Quote: Originally Posted by _Dejan_ View Post
I will say in this way. This software doesen't work right with my car. You can see on photos that doesn't show right values and Im shure that my car on idle don't run with 200-240rpm. So Im looking for software where I can "calibrate" this values...
P.S. by hyperterminal I ger values of real rpm so I get 800-900
What kind of vehicle do you have? Are you sure it's fully OBD-II/EOBD compliant? Based on your posts, it sounds like it isn't fully compliant.
However, our PCMSCAN software has a powerful feature that will be able to fix this. Just create a custom Javascript parameter (go to the Tools menu -> Script Editor) that takes the value of SAE.RPM and multiplies it by 4. Then you should be seeing the proper RPM. Of course, you'll have to edit the dashboard layouts to use your new script RPM parameter.
PCMSCAN - Check it out at: http://www.palmerperformance.com
PPE is offline   Reply With Quote
