Now that things are winding down on this front, I wanted to step back summarize the BOM. I also wanted to compare cost-to-date against my $800 budget cap.
Code:
Description Supplier Cost
NEC ST-NLT NL8060BC21-03 LCD Panel Future $378.00
(Transflective, 800x600, 600cd/2, 600:1, 16.8M)
NEC 84PW041 Inverter Future $ 35.00
Digital View ALR-1400 VGA-to-LVDS (4171000XX-3) Mouser $134.00
Digital View LVDS Cable (426493000-3) Mouser $ 40.00
Digital View Power Cable (426013800-3) Mouser $ 13.00
Digital View Inverter Cable (4260583-00) Mouser $ 9.00
Digital View RS-232 Control Cable (4260902-00) Mouser $ 11.00
8.4” IRTOUCH E-08-U-BC IR Touchscreen w/ 3M AR-MR200 MCT $185.00
Aluminum Hobby Enclosure (10” x 14”) Fry’s $ 25.00
$830.00
Not so bad, right? Well, the astute reader will realize that I am wearing my Enron accounting hat.
Code:
Unused Parts/Materials
Custom Cabling Assembly (now cannibalized) MCT $ 80.00
LVDS-07G (awaiting rocket launch) Mini-Box $ 33.00
$113.00
So, I have spent about $945 total. Let's not get into tax and shipping, it's not that much.
Note that Digikey sells the IRTOUCH TS and the 3M AR-MR200 film. You will need to find an off-the-shelf cable assembly for the NEC 84PW041, or crimp your own. Whenever possible, I leverage a machine assembled wiring assembly and splice into my application.
I still need to remove the potentiometer and wire in the inverter brightness controls to the ALR-1400. This should be the last bit of tweaking, other than the mounting hardware. I will try to use a small USB hub to consolidate the IRTOUCH and a USB-to-RS-232 adapter into a single USB line that I run to the dash.
Given my display budget overrun, I will definitely be doing my own fab work on the dash. If I draft the measurements for the aluminum plate on the PC, I can print out a drill template at actual size and avoid the parallax errors from marking the holes with a mechanical pencil.
I will stop posting to the
IRTOUCH thread and combine with this thread. Hopefully I will get some pictures and video of this setup with the IRTOUCH in direct sunlight this weekend. Note I have resumed my dash fabrication journey here:
http://www.mp3car.com/vbulletin/fabr...brication.html
