Quote: Originally Posted by
bcohen5055
I've tested it here using the nslog and it looks like the software functions correctly. Take a meter and test your digital outputs for 1 and 4. Also try a different relay in the port. I think it's a hardware problem.
Nope, Using The Phidgets program 'Phidget Interface Kit' all switches work correctly, in your program, 1 and 4 turn on, but don't turn off.
Another suggestion, is when you turn "on" a switch it should change color to indicate that its on, if I have fog lights, on and I use the software switch, I have no way to tell if there really on.
Jonathan
