Go Back   MP3Car.com > Mp3Car Technical > MacCar > Amp2/AmpXM
Old 10-02-2008, 01:55 AM   #1
paulsgto is an unknown quantity at this point
Anyone get XM to work?
I've got an xmpcr here and am having no luck getting jxm, amp, or macxm to work. Seems I'm missing the javax.comm dealie. Installing it seems over my head. Downloading xcode right now to see if I can follow along with rxtx.org wiki.
Gotta get this done quickly and I'm thinking of just running bootcamp and windows xp (will it even work then?)
paulsgto is offline   Reply With Quote
Old 10-02-2008, 10:44 AM   #2
NeonDev's Avatar
NeonDev is an unknown quantity at this point
if installing javax.comm is over your head then doing anything with Xcode will drown you.
Bugbyte said he will be porting my cocoa native XM module code to AMP in coming months. that does not require javax.comm and is fully compatible with the XM PCR
check us out at: www.neonboombox.com
NeonDev is offline   Reply With Quote
Old 10-02-2008, 12:00 PM   #3
Wow you really saved my a** here with your prog.
How about that? A program that works right outta the box!
I appreciate the hard work that goes into developing all these front ends, lord knows it's over my head.
Thanks everyone.
Old 10-02-2008, 12:37 PM   #4
NeonDev's Avatar
no problem, I'm sorry it doesn't work as well as I would like
IIRC the java based ones didn't work all that smoothly either... hopefully bugbyte or somebody else who cares more about XM then myself will really put some time into it and make this native solution better.
Old 10-02-2008, 09:50 PM   #5
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Yep, we'll *be* working on it. Which means that we aren't working on it just yet.
You have to install that javax.comm module into java to get it to work, but I don't think that AmpXM works with the XMPCR. At least, I haven't tested it with an XMPCR.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 12-19-2008, 09:08 AM   #6
minicoopS007's Avatar
minicoopS007 is on a distinguished road
Yes we (bugbyte and minicoopS007) need to work on it. I've started on the integration into AMPXM (AMP 1.x)...
Cheers
minicoopS007 is offline   Reply With Quote
Old 12-19-2008, 04:34 PM   #7
Bugbyte's Avatar
I took a look through the code. Thanks for commenting it and making it easy to read!
We'll get working on it for AmpXM.
Want to:
-Where is the iBug?
Old 01-02-2009, 11:22 PM   #8
Question iAmp/Amp2/AmpXM/Amp_TV
I call it iAmp; also known as Amp2/AmpXM/Amp_TV. In any case I have integrated the cocoa XM code from NeonDev into iAmp. Kudos NeonDev! My version of iAmp runs under OS 10.4.11. Bugbyte will build it under leopard. I use powermate and or keyspan IR remote to control iAmp. With powermate I can't simulate the "esc" key input. I could write an applescript to perform this, but I was hoping someone here has already done it. This is really a minor issue. The core issue I'm having is with the Mp3Car USB adapter for XM Direct. The device (Mp3Car USB adapter for XM Direct) appears under usb hardware profile. I thought this device was an FTDI usb<-->serial compliant. The device does not appear under /dev/cu.* or /dev/tty.*. Also it does not appear in the network port configuration. I have FTDI drivers installed.
Note that I used to be able to control my XM Direct tuner with HXM via my DIY usb-serial cable.
Advertisement Sponsored links
XM Radio - COMPLETE REWRITE mitchjs Road Runner 93 07-16-2008 12:17 PM
XM Direct + Serial = Mouse? jpsndtek Hardware Development 4 12-23-2007 01:56 PM
XM to the Carputer TokyoJoe Hardware Development 9 09-13-2006 09:03 AM
How do I get the XM direct unit to work? minghi Off Topic 2 04-22-2005 06:52 PM
